Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 02-19-2020, 09:01 PM   #1
arbitarytwist
City & State: BC
My Country: Canada
I'm a: Knowledge Seeker
Default LG 43UK6300 - Audio & Backlight, but no Video
I have a LG 43UK6300BUB that has Audo and Backlight.
I am no TV expert, but have done some troubleshooting on TV's in the past.
When i turn the TV on, i can hear audio and the backlight turns on, but there is no picture. Most of the trouble shooting videos i have seen, have a seperate main and T-Con board, but it seems like on this unit, the T-CON and Main board are the same.
I have checked the voltages on the connector from the Power Supply and i seem to be getting 13V, 3V & 2V to the Main board. I tried disconnecting one panel cables at a time and still no video on either half of the TV.
I haven't found anything obvious, but was trying to check the voltage to the display, but don't see any test ports, so would appreciate some help in troubleshooting.
This TV is about 16 months old with a manufacture date of 08/2018.
I have attached some pictures for reference.
arbitarytwist is offline   Reply With Quote
Old 02-20-2020, 09:34 PM   #2
arbitarytwist
City & State: BC
My Country: Canada
Default Re: LG 43UK6300 - Audio & Backlight, but no Video
OK did some more looking around and seems like a burnt Transistor. I wasn't that pronounced, as in the original pics i posted, but i figured i try the oven bake and it made it more obvious. The behavior is the same as before the bake in.
I have attached some closeup pics (before over bake as seen in Pic #2 in original post).
How would i go about finding what the transistor and perhaps replace it. The two resistors above it when measured are around 70 Ohm each although there is some discoloration on one of them perhaps from the burnt transistor.
The part # for this mother board is EBU64688103 and wondering if i use EBU64688102, will that work, or would that be a different firmware ?
The complete model # for this TV is 43UK6300BUB.
Old 02-21-2020, 01:31 AM   #3
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I would remove that Transistor and then check the resistance between Ground against all 3 empty pads of that Transistor to see if any one of them shows <50 Ohms.
If not then put the cables between the main board and the LCD panel back in place and recheck the resistance again to see what it shows on all 3 pads.
We want to make it is not short circuit in the LCD panel that causes the Transistor to burnt out.
__________________
budm is offline   Reply With Quote
Old 02-21-2020, 09:31 AM   #4
arbitarytwist
City & State: BC
My Country: Canada
So i took some measurements with panel cables disconnected to ground and am getting 30 KOhm, 50 KOhm and 80 Ohms on the emitter (leg by the R1104). With the panel cables hooked up, there isn't much change.
Old 02-22-2020, 10:53 AM   #5
arbitarytwist
City & State: BC
My Country: Canada
With the postage values do you concur there is no short ? How would I go about finding a replacement transistor. Can't find any part# on the old one.
Is there anything else I could do to be 100% sure it's not the panel.
Old 02-25-2020, 11:01 PM   #6
arbitarytwist
City & State: BC
My Country: Canada
So i did a bit more digging and following are the voltage readings i got
OFF (V) ON (V)
B 7.8V 10.5V
E 7.8V 13 V
C 0V 0V (No Transistor in Place)
This makes me think its a PNP transistor. I am wondering what i can use as a transistor to make this work.
Old 02-27-2020, 02:36 PM   #7
sintv
City & State: cowdenbeath
My Country: scotland
Disconnect one of the screen cables and see what happens. Iv just scrapped a slightly older LG although it had a Tcon board. Symptom was no video but backlights and sound ok. When I removed one cable, picture came on half the screen.
sintv is offline   Reply With Quote
Old 02-27-2020, 08:53 PM   #8
arbitarytwist
City & State: BC
My Country: Canada
Quote:
I tried that already. Makes no difference.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
