MBP Mid-2012 Missing Question-Mark Folder
    The MB chimes and has a working screen which illuminates as normal.
    I've followed the guides on SMC / PRAM resetting.
    I've removed the HHD and reset everything again, still no luck.
    I've tried to re-install Mac OS using a USB stick, again no joy.
    Nothing seems to recognised when using usb, although they do flash when plugged in.
    What should I try/do next.
    Any help is greatly appreciated.
    Re: MBP Mid-2012 Missing Question-Mark Folder
    Boot into Internet Recovery, erase the drive with Disk Utility and reinstall macOS.
      Followed your instructons, initially I had no joy, although the screen did dim momenterally after a few seconds but nothing happed.
      So I tried again with a second display connected through the displayport and hey presto I got an image, the MB screen is still white.
      I turned the MB off insterted a HDD with Lion already installed and checked specs, sys info etc.
      1. When opening window about this mac it only states it's a Macbook Pro nothing about size or screen. I've included an image(1).
      2. Changing the resolution worked fine but the display tab on about this mac states it's a 17 inch. I've included an image(2).
      My MBP is a 13-Inch Mid 2012 Core-i5-3210M.
      Thanks again.
        I interpreted your issue as operating system not found. You mentioned the screen to be working, not showing a solid white background.
        If there is an issue related to LCD, first thing would be to try a known good LCD.
          Did you check the lcd connector on the board and the lcd cable? When you say working screen is it a known working screen or are you going by the fact it illuminates? If its the latter then try a known working screen.
            I've disconected the screen and connected to a MBP mid-2011 where it works fine, I can see the OS on screen.
            So atleast we know the screen is fine.
            The LVDS connector looks fine on the MBP, but I've included an image.
            I guess it's a case of fault finding along the gpu to screen output? or am going in a totally wrong direction.
            Thanks again for the help.
              It's a 13" so GPU is indide CPU. Check voltage on pins 2/3 of J9000 and all pins of U9000
                Can you check diode mode on all 6 LVDS lines (pins 8-18) and voltage on pin 3 on J9000 (lcd connector) ?Is the board number 820-3115?
                  J9000:
                  Pin 1 0.26v
                  Pin 2 0.26v
                  U9000:
                  Pin 1 3.3v
                  Pin 2 0.24v
                  Pin 3 0.24v
                  Pin 4 0.26v
                  Pin 5 0.26v
                  Pin 6 Gnd
                  6 LVDS lines gave no shorts, with the following readings:
                  8 1768 ohms
                  9 1982 ohms
                  11 1758 ohms
                  12 1963 ohms
                  14 1746 ohms
                  15 1994 ohms
                  17 1839 ohms
                  18 1903 ohms
                  The board is 820-3115-B.
                  Thanks again for all the help.
                      U9000 pins 2/3 should have 3.3V, they are connected to PP3V3_S5 which must be present if the machine turns on. There is probably a break in the line.
                        J9000
                        pin2 0.26v
                        pin3 0.26v
                        Miss labelled the pins sorry
                          If I solder two small wires from Pin1 of C9009 to pins 2/3 on the U9000, this would fix the issue?
                            If there is voltage on c9009 pin 1 then yes otherwise you'll need to go further back
                              Thankyou Piernov and Luckdip for all the help.
                              Soldered the wires as mention earlier and this solved the problem. My question mark folder has now been found.
