best cheap/free scores 1.1
This is a sticky topic.
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    #4661
    Re: best cheap/free scores 1.1
    If you press Alt+PrintScreen then only the window that has focus will be captured.
    All these years using Windows, and I still never knew this one. Thanks, I learned something useful today. I suppose my expert cropping skills in MS Paint will no longer be needed as much.
    Originally posted by Topcat
    Yea, I'm aware of the little camera thingy....I'm just old school I guess, and do things the old way, manually......
    I don't blame you, I'm the same way, using old programs and utilities from 10-15 years ago that still seem to do the job today (if not better sometimes.)
    More specifically, people will probably have to pry Office 2003 from my cold dead hands before I give it up.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I got curious and tried it....it took a screen shot of all 3 monitors.... The image size was 7680x1600, saved as PNG @ 3.2mb!!
      Same. PSP8 is great for basic things and its portable if you just dump a working directory to a system or run it from an external HDD/USB.
      I'm still running office 2007, and the only reason I up'd from 2003 was I needed to work on some .xmls that for some reason 2003 wouldn't properly format. The way MS handles office today is retarded....they know that the OS war is over....so now it's rape for programs. I got my first taste of a Win10 laptop in "S-mode" the other day. What a crock of shit that was.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        #4663
        IDK Alt-PrintScreen works fine for me - just screeshots only the active Windows I have open. But maybe across multiple monitors, it gets tripped up? I'm a single-monitor guy, so I'll probably never know.
        Also 3.2 MB for 7680x1600 from PNG format can be considered very good or very bad.
        Like I said, PNG is great for images with large blocks/areas of solid colors, but of limited color space (i.e. sub 256-color workspace.) Try taking a large screenshot of large window that has only text and basic 8-bit or lower graphics. Then save to PNG and JPG. The PNG should be only be a few tens of KB of data and there will be zero color compression (PNG is loseless.) The JPG will likely be at least a few hundred KB for large images, if not up to a MB or two, depending on compression quality. Now take a very colorful picture from your camera that's already saved in JPG and re-save/convert to PNG. Result: the file size will likely be much larger by a factor of 5-10x or more, depending on how colorful the picture was... though it still won't beat 24-bit BMP.
        Yup, same with Photoshop 7 (i.e. pre-CS series.) That's what I use.
        Maybe it was saved with a newer version of Excel?
        I have the FileFormatConverter patch installed, which allows my 2003 to open the newer Xlsx and Docx formats, but not save natively in them.
        Yeah, something similar happened to me on my previous job. My laptop was Windows 7, but with Office-365 installed from the company, including Outlook. For whatever reason, the Office-365 subscription was not updated, so O365 went in safe mode and practically became useless. By the time IT was anywhere close to solving the problem, I just gave myself local admin access, installed Office 2007, and was puttering again. IT never solved it, though... which is OK - my contract expired 2 months later, after which I left. So who cares.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          #4664
          lol i wish there was a button to thank someone for this useful post like on other forums. so thanks. didnt have this one on my list of windows keyboard shortcuts. this will save a lot of time not cropping desktop screenshot images. thanks for a more productive me now... lol!
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            • Romania
            #4665
            Scored these yesterday:
            Acorp 5VIA3P - VIA VPX chipset, Socket 7. Had slightly rusty pins (about 3, and unimportant ones at that) on the southbridge but otherwise it booted first try using P166 non-MMX, S3 ViRGE/DX PCI and a 64MB PC100 stick.
            Bunch of laptop HDDs - all dead it seems
            Toshiba L300-18D - bad NEC-TOKIN, scrapped the casing and board, reused the speakers and made a better L300-18D using a newer board that has GM45 chipset + WiFi Link 5100, SATA DVD-ROM and already had the NEC TOKIN replaced w/ 4x330uF caps with another casing that was in better condition. Also saved the HDD and RAM covers before scrapping the original 18D casing.
            Packard Bell iPower GX-M-100FR - works fine but does not have battery, CMOS cell needs replacement (three pins, quite similar to some DELL RTC batteries) otherwise specs are quite okay - 9800M GTS (1GB I think), Bluray (not original to it tho, while the front cover states BD, the unit itself is from a HP DV7 1st gen), 320GB HDD and 4GB DDR3.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
            • Dan81
              SNES-powered
              • Oct 2013
              • 1865
              • Romania
              #4666
              Today's scores:
              Fujitsu Siemens Amilo Li3710 - had broken DC jack, thankfully I easily fit a Acer DC jack in there and works fine. Originally had 2GB of RAM, Celeron M 900, 160GB HDD. New specs are 3GB of RAM, C2D T5800 and same HDD.
              HP-Compaq 6735s - small and nice 15.4 machine. Had no RAM and HDD, a sorry excuse of a Sempron SI-40 and a bad chipset. Reflowed the chipset, replaced the already ripped thermal pad with a thicker one from a junked LCD TV, CPU is now a Athlon X2 QL-66, has 2GB RAM and a 320GB WD Black I had around.
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                IBM PS/2 model 55SX - Unknown condition, PSU needs repair
                IBM Proprinter X24E - Unknown condition
                IBM Model M PS/2 - In dire need of a bolt mod
                Permanently Retired Systems:
                Kooky and Kool Systems
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  Was given a HP DV6500, dual core @ 1.9GHz 4gb RAM 150gb slowass spinner. It had the typical power on then shuts off 3 seconds later. Reflowed the GPU, and now working. Wiped Vista home off it for Win7 pro....and fine now....as a matter of fact, this post created from it. Batt won't hold a charge....the only reason I messed with it at all, the case & screen are in mint condition.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Good luck. The one time I tried reflowing (similar HP) it lasted 6 weeks before having the same failure again. As much as a PITA they are to work on, I didn't bother trying again.
                    sigpic
                    (Insert witty quote here)
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      I've done a few of them, the success rate is ~75%... I also apply a slightly thicker piece of that heatspreader stuff (not really sure what it's made of, but it feels kind of silicone-ish), which applies a little more pressure from the heatpipe. The only one I completely hosed, I got it way too hot and the GPU actually moved....yea, that one was all done.
                      Something like this I'll either donate or sell cheap with the gentlemen's agreement of don't bring it back!
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Next time I'm in MO I might drop said laptop. I think I pulled the HDD and RAM but it's all still intact otherwise. Is a late 2000's Turion X2 if memory serves.
                        Issue is I/O and devices no-show... not the usual black screen/ no POST we're used to.
                        sigpic
                        • Dan81
                          SNES-powered
                          • Oct 2013
                          • 1865
                          • Romania
                          #4672
                          Turion based DV6000s are a literal plague, at least for me.
                          The Intels are sweet if they're the PM965 variants. I have 2 of those (one has a Pentium T4300 and the other a C2D T6500), both have 8400M GS and PM965 so I'm at least half safe on that. 460900-001 is the code if you need to find the one w/ 8400M GS, 460902-001 for the X3100 iGPU.
                          I guess HP didn't learn the whole Turion line up until S1G4 was a hot mess in every aspect. And the fact that the GF6100 chipset should never be paired with S1G1 CPUs, the worst heaters out there.
                          Main rig:
                          Gigabyte B75M-D3H
                          16GB DDR3-1600
                          Delux MG760 case
                          • lti
                            • May 2011
                            • 2547
                            I saw a Toshiba Tecra M9 run 11 years before the GPU died. It had a dedicated GPU heatsink, even though it was a low-end Quadro NVS GPU (a business model, not a workstation). It only had one fan blowing through both heatsinks, but it's better than just extending the CPU heatpipe and having it float above the GPU (which is still done today).
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1865
                              • Romania
                              #4674
                              Scored a sad looking Acer 2930.
                              T5800, 250GB HDD, 2GB of RAM, and a Lite-On/Philips DVD-RW drive. 12.1' CCFL screen is smashed, KB has missing keys (KB should be easy to replace since it's the same as on some Travelmates) but otherwise boots fine. Chipset is GM45, so guess it's a 4500MHD for this one.
                              I'll have to track down a LCD from dead 2920s, since the connector is some idiotic 20pin connector that I couldn't find anywhere else.
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                              • jayjr1105
                                • 281
                                Got a PS2, Controller, Game, Memory card and Power Cord for $10 today. It's a 39001 too.
                                Ryzen 3600x
                                16GB Patriot 3600MHz
                                MSI B450 Gaming Plus
                                MSI Air Boost Vega 56
                                Acer 32" 1440P Freesync
                                Rosewill Capstone 750W
                                Hakko FX-888D Station
                                FX-8802 Iron
                                MG Chem .8mm 63/37 RA 2.2%
                                  • 30978
                                  nice, you can put a loader on the memory card and fill a usb device with games
                                  (or buy a chinese ps2>sata HD adapter for $20 and fit a drive in the back)
                                  • jayjr1105
                                    • 281
                                    I'm trying to figure out which way I want to go. Apparently there is a kit to convert the oem network adapter to work with sata drives and it's more reliable. Not sure what to do yet.
                                    Ryzen 3600x
                                    FX-8802 Iron
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16956
                                      Yea, it is a Turion.....but so far so good.... If I can donate it and never see it again, I'm good....if it gives someone service for a while, mission accomplished.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • Skunch
                                        • Jun 2020
                                        • 28
                                        My current machine is a mix of killer deals and free stuff. I've got an asus rampage iii formula for free, and I bought a 1070 from a coworker for 200 CAD. I'm running a 980X with 24gb ddr3, and it's booting off of a samsung 950 pro nvme drive.
                                        • Dan81
                                          SNES-powered
                                          • Oct 2013
                                          • 1865
                                          • Romania
                                          #4680
                                          As a fair warning, the last and only Turion based DV6000 I reflowed and gave to someone worked for one more week then quietly died forever...so I'd be careful with that one...
                                          It was a trade of sorts - I got his G86+Intel based DV6000 and gave him the Turion+Go7200. The Intel still runs to this day (and surprisingly cool for a G86 chip, though not very surprised since I have done a few small mods to the HSF that HP could care less to do)
                                          He said he'd drop by and bring the "roadkill" one of these days, and I've talked him into replacing that DV6000 for free with something better, and am still looking for some run-of-the-mill Acer or ASUS w/ a G84, G86 or G9x GPU to throw his RAM and HDD into.
                                          G8x chips run fairly well if cooled properly. Add a copper shim to the core if it uses thermal pad, and it runs great. I can also say I liked ASUS' initiative of making the GPU HSF on my G70S (it has 2 separate heatsinks in a sandwich - one is an big aluminium CPU HSF (though the base for the CPU itself is copper) and the one right above it which cools the SLi chip as well as the GPU, and that one is full copper.
                                          Main rig:
                                          Gigabyte B75M-D3H
                                          16GB DDR3-1600
                                          Delux MG760 case
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
