Apple MBP 13" 820-2936 not Load Battery
    I got a Apple MBP 13" here with a failure on the Power Rail. It is not charging the battery and not working on PSU. It only works on Battery. The PSU light is green or off. When i remove the battery the MBP goes out immediately.
    I found those two topics:
    https://boards.rossmanngroup.com/thr...harging.32412/
    https://de.ifixit.com/Antworten/Anse...harged+battery
    I measured pin 17-18 and 27-28 on the U7000, those are 3.3 Ohm and 20 Ohm, Just like in the the first link. So i replaced the U7000 with one of a spare board but with no success. So in the first topic someone replaced the Q7030, how to i measure that thing? The diagram looks like the picture added.
    In the second topic they are replacing a resistor going bad, but mine ist still at 0 Ohm.
    Re: Apple MBP 13" 820-2936 not Load Battery
    Please clarify, the state of the LED on the Magsafe is very important.
    Also before replacing anything you have to take some voltage measurements.
      So, now i have some time for this older MBP. The LED is green, mostly, but at some time it just turns off.
      What should i measure? Power incoming is 16v
        If Magsafe LED is green but sometimes not present it's most likely bad contact. Known good Magsafe and DC-in board should take care of that.
        You have to measure the main power rails such as PP3V42_G3H and PPBUS_G3H with battery disconnected. I'd recommend watching Louis Rossmann videos as this topic is already covered extensively, probably even a very similar problem on the same board.
          As piernov said watch Louis's videos on the one wire circuit - you need a steady light on the magsafe before moving forward.
            The green light sais on for now.
            PP3V42_G3H = 3,34V
            PPBUS_G3H = 0,08V But it is slowly rising. Now at 0,10V So there could be the problem.
            The device is turned of at this time of measuring.
            I checked the rossman forum, not the videos yet.
              So i found this video: https://www.youtube.com/watch?v=wPxYPrnoMZ4 there he replaced the U7000, just as i did. Well i took it from a broken board.
                There's a lot more to the troubleshooting process than randomly replacing a component.
                  You need to measure voltages on U7000, also check for a short on PPBUS_G3H
                    The voltages look normal except the PPBUS_G3H. What voltages should be on the U7000? There should not be a shortage, because it is working from the Battery. When the Battery is connected the PPBUS_G3H is around 11 Volt.
                    What voltage should be on the SMC_BC_ACOK? But the light is green. I followed the steps in the Video and all seems the same issue, low PPBUS_G3H around 1 Volt, no voltage on the Q7030 and on the white Fuse (which is directly connected to the PPBUS_G3H).
