Old 09-24-2020, 04:57 AM   #21
Spider1211
City & State: Morcellement
My Country: Mauritius
Line Voltage: 230VAC, 50Hz
Default Re: Alienware M17x R4 no power, low resistance 5v/3.3v to GND
Originally Posted by maxslo View Post
Edit: on working laptop the resistance to ground measured on PL11 was actually 0ohm when the laptop was turned on o.O how can it be dead shorted to ground.
If you measured resistance while power was applied to board you will get erroneous reading and may appear as 0 ohm.
Spider1211 is offline   Reply With Quote
Old 09-24-2020, 05:08 AM   #22
maxslo
City & State: Ljubljana
My Country: Slovenia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Ok, good to know then, i thought there must be something wrong with the reading, there is no way it could be shorted and still at 5V
maxslo is offline   Reply With Quote
Old 09-24-2020, 07:09 AM   #23
qayyum786
City & State: MUMBAI
My Country: INDIA
Line Voltage: 220 volt
Arrow Re: Alienware M17x R4 no power, low resistance 5v/3.3v to GND
remove D26 and make a jumper from R262 to power button Pin 4 I have solved 1 issue in Acer through bypass 51on logic
qayyum786 is offline   Reply With Quote
Old 09-24-2020, 08:00 AM   #24
maxslo
since dellxps has found that his board powers on with 19v on the power button, i don't think this is the issue, however i can try it if there are no other options.
@dellxps15 do you have voltage at PL10 and PL11 when in off state?
Old 09-24-2020, 08:31 AM   #25
dellxps15
City & State: Italy
My Country: italy
as i told before 3.3, 5volt and bios volts comes only after i press power botton
dellxps15 is offline   Reply With Quote
Old 09-24-2020, 09:43 AM   #26
maxslo
Weird that there is such a difference between r3 and r4... Ok i'll give the jumper wire a try.
Old 09-24-2020, 11:08 AM   #27
dellxps15
City & State: Italy
My Country: italy
wait before make a jump wire.... 3.3 and 5 volt should come even if we have 19 volt on power botton.
check all 3.3-5 volt ic contact and pins before do anything, because i read u worked on that area.
on some post over i posted if u have 3.3 volt on mosfet near kbc...
read post #18
Old 09-24-2020, 11:16 AM   #28
maxslo
Yeah all contacts are ok, but i have all 4 fets off and both coils and caps, i'll first put those back since we figured that 15ohm is ok as the r3 board has 15ohm too,
I replied to #18 in #20
Old 09-25-2020, 11:02 AM   #29
maxslo
Ok, I've put everything back together, the PQ7 is 19V just like you said.
Measurements on the PU4 are:
1: 0V
2: 0V
3: 2V
4: 2V
5: 0V
6: 0V
7: 0V
8: 3.3V
9: 4.54V
10: 0V
11: 0V
12: 0V
13: 3.13V
14: 2V
15: 0V (GND)
16: 19.5V
17: 5V
18: 0V (NC)
19: 0V
20: 0V
21: 0V
22: 4.54V
23: 0V
24: 0V
@dellxps15, i've checked the EC_ON line from KB930 at PQ62, all 3 pins measure 0V, does that sound ok?
Old 09-25-2020, 01:01 PM   #30
dellxps15
City & State: Italy
My Country: italy
1: 0V
2: 0V
3: 2V
4: 2V
5: 0V
6: 0V
7: 0V
8: 3.3V
9: 4.54V
10: 0V
11: 0V
12: 0V
13: 3.13V
14: 2V
15: 0V (GND)
16: 19.5V
17: 5V
18: 0V (NC)
19: 0V
20: 0V
21: 0V
22: 4.54V
23: 0V
24: 0V
these are pu4 volts without pressing power botton ? i have the exact 100% same value as your p4u without pressing power botton
voltage on u36 ec bios ? near kbc
pin 1:3.3
pin2 1.2
pin3 3.3
pin4 0
pin5 1.3
pin6 0
pin 7 3.3
pin8 3.3
Old 09-25-2020, 01:19 PM   #31
maxslo
pin 1:3.3
pin2 1.2
pin3 3.3
pin4 0
pin5 1.3
pin6 0
pin 7 3.3
pin8 3.3
Yeah those are without pressing power button... even if i do it makes no difference, laptop doesn't power on, 3.3 and 5v dont come on
Ok now here are differences:
U36
1: 0V (3.3V for you, this comes from FSEL KB930)
2: 0V (1.2V for you, this comes from FRD KB930)
3: 3.3V
4: 0V
5: 0V (1.3V for you, this comes from FWR KB930)
6: 3.3V (0V for you, this comes from SPI_CLK KB930)
7: 3.3V
8: 3.3V
basically all the pins coming from the superIO have different values :S
Old 09-25-2020, 01:55 PM   #32
dellxps15
City & State: Italy
My Country: italy
try with these bios and ec bios....
bios is u48
ec bios is u36
use same version a13 for both
https://www.badcaps.net/forum/showthread.php?p=991153
Last edited by SMDFlea; 09-27-2020 at 02:34 PM.. Reason: Post copied to bios requests section
Old 09-25-2020, 02:47 PM   #33
maxslo
That's the same archive i used, only that i used A11 ...
I'll give it another try tomorrow with A13, if that doesn't help it's most likely the KB930 right?
Old 09-27-2020, 10:16 AM   #34
maxslo
I've been busy with cousin's Clevo laptop not powering on anymore, i'll open a separate thread for that, i'm in the process of reprogramming the chips to A13 versions, i'll update you shortly about any changes.
Old 09-27-2020, 11:05 AM   #35
maxslo
@dellxps15
lol can't believe it, the A13 worked... it's odd, but why wouldn't the A11 work too :S
I guess i jumped to conclusion too fast...
Now i have to make sure everything else is working as supposed to.
Regarding the 19v on the power button, the aforementioned Clevo is also Ivy bridge, has the same 19v on the power button like the M17x R4 and has no power on 3.3v and 5V until it's powered on.
I guess the difference between sandy and ivy bridge really is that great when it comes to off state and power button lol
Old 09-27-2020, 02:42 PM   #36
dellxps15
City & State: Italy
My Country: italy
so..... notebook is giving post to aliwnware logo ?
what problem has the clevo ? i have a clevo as ordinary pc... a p870km with z270 chipset and i5 9600k with modded bios . once it shut down after 1 sec... and was 1 defective ram.
Old 09-27-2020, 02:58 PM   #37
maxslo
Yeah it posts and has already loaded to windows,
I've fully assembled it and looks like everything is recognized and working
Next i'm adding the external GPU to the laptop.
The Clevo shuts down after 1-2seconds.
I've swapped around the CPU, used all 3 different ram slots... BTW, weird, why would you have odd number of ram slots o.O
The laptop stays on if i remove ram from all slots, no beeps or anything.
All the rams are tested in other system so they are good, however when i add a ram to this one it wont power on.
Power on sequence is fully completed and then it turns off. The laptop is W350ET.
Old 09-27-2020, 03:02 PM   #38
SMDFlea
City & State: York
My Country: UK
Start a new thread for the clevo please .
SMDFlea is online now   Reply With Quote
Old 10-14-2020, 11:47 AM   #39
dellxps15
City & State: Italy
My Country: italy
sorry for late. today i wanted to look at my board and after flashing a13 bios and ec pc didnt power on annymore. wich version of ec and bios did u used ?
same a13 from rar for both bios and ec, or different ec and bios ?
Old 10-14-2020, 01:56 PM   #40
maxslo
I used the A13 for both, i made sure that the programming was ok. (Reading it back after write and copare).
A11 didn't work for me and i haven't tried A12.
