Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Thread Tools Display Modes
Old 08-06-2020, 11:40 AM   #1
peterwheat
City & State: Huntsville
My Country: United States
I'm a: Knowledge Seeker
Default Yamahaha RX-V679 DC PRT High
Hey all,
I have a Yamaha RX-V679 that is entering protection mode after a few seconds of turning on. Shows "DC PRT 77H" error when I disable the auto protection.
All speaker terminals read ~0.4 volts across, except for the surrounds, which read 0 volts for right and ~0.9 volts on the left, which increases until the receiver kicks off. I'm thinking this is my problem child.
I took it apart and started testing the main output transistors, and didn't see anything blown open (I did this without desoldering, however I compared to nextdoor channel and all were very similar). The attached picture shows the transistors. Attached picture shows them.
Question is, what is my next step for testing?
Thank you for your help!
Service manual is located here, too big to attach
https://drive.google.com/file/d/1VtI...ew?usp=sharing
peterwheat is offline   Reply With Quote
Old 08-06-2020, 12:20 PM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: Yamahaha RX-V679 DC PRT High
most likely the differential transistors . is there no dc offset adjusters ?
petehall347 is offline   Reply With Quote
Old 08-06-2020, 12:47 PM   #3
peterwheat
Which ones are those?
Not that I am aware of, but frankly I'm not that knowledgeable on receiver electronics.
Old 08-06-2020, 02:35 PM   #4
petehall347
have you got a schematic ?
Old 08-06-2020, 02:35 PM   #5
peterwheat
Update:
I put things back together so I could reverify some voltages. I checked all the active speaker terminals for voltage again, and everything that's active is reading about 400 mV, with close to 0 on the non active channels. I had a speaker hooked up to one of them, and it sounded very distorted unless it was at a whisper like loudness.
Old 08-06-2020, 02:36 PM   #6
peterwheat
Quote:
Schematic should be in the service manual above, I can attach the main board pdf possibly?
Old 08-06-2020, 02:38 PM   #7
petehall347
need to check the power supply first . if thats wrong it will never work properly
Old 08-06-2020, 02:39 PM   #8
peterwheat
Should I just be checking voltages coming out of the power supply then?
Old 08-06-2020, 02:47 PM   #9
petehall347
yes check those first .
Old 08-06-2020, 03:29 PM   #10
peterwheat
Checked these voltages, all correct. (within 5% or so)
Old 08-06-2020, 04:17 PM   #11
petehall347
look for the -12.4v rail .
Old 08-06-2020, 04:31 PM   #12
peterwheat
On the main board, correct?
Old 08-06-2020, 05:03 PM   #13
petehall347
yes .if you look at the input to the amps on the schematic its there .
Old 08-06-2020, 05:09 PM   #14
petehall347
also measure at for example Q1002 base .should be 0v ..i ask this because offsets are high when active . might be stray voltage getting in here .
i have a feeling the fault might be the input switching chips .
lets see those voltages first though before i get carried away too much .
Old 08-06-2020, 05:47 PM   #15
peterwheat
Reads at -12.2V
Old 08-06-2020, 05:57 PM   #16
peterwheat
Q1002 is in a Y shape, from the bottom of main board
-0.45V 0V
56.58V
Old 08-07-2020, 01:53 AM   #17
petehall347
what does it measure when that channel inactive ? like not selected .
Old 08-07-2020, 02:19 AM   #18
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Quote:
Originally Posted by peterwheat View Post
Hey all,
So the Surround Left is the only one that has output offset that goes too high after a while then the receiver goes into output high DC shut down?
Is it Surround Left? Or is it Surround Back Left? I ask because you were asked to check Q1002 which is for Surround Back Left, not Surround Left. Please Clarify as to which Left channel is bad.
Below is for Surround Left checking:
Once it goes into shutdown,what DCV do you get on jumper J245 (close to Surround Left output inductor L6, see service manual PDF page 118)?
Is it Positive or Negative Voltage reading with ref to GND?
__________________
budm is offline   Reply With Quote
Old 08-07-2020, 08:17 AM   #19
petehall347
i only used Q1002 as an example .. its fairly straightforward looking at the schematic .
from what i read offsets are only high when channel is active . and not just one channel . 400mv offset .
i haven't studied whether it cuts the speaker off or mutes the input when not selected .
Old 08-07-2020, 10:00 AM   #20
peterwheat
SR: 0.353
SL: 0.302
C: 0.300
FR: 0.358
FL: 0.305
SBR: -0.009
SBL: 0.814
Those measurements are with all channels selected.
waiting on it to kick off so I can measure the jumper now.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
