HP DMI Tool NBDmiFit
Re: HP DMI Tool NBDmiFit
Originally posted by imranromi View PostPost here bios dump if will fix.
- HP BIOS Configuration Utility (BCU) - unsuccessful
-- wndmifit is not common to download - most of download links are going to 404 error or contain fake files - tried so far v 2.09 then v 1.1d to 1.14D
I am keep looking
wndmifit is included inside the nbdmifit folder. Page #1 post #1 of this thread has different nbdmifit versions,try 2.10 in UEFI.The site is working ok, no 404 pages for me. You can post your bios in the "Bios Requests" sub forum if you want someone to try repair it for you - https://www.badcaps.net/forum/forumdisplay.php?f=40
.Last edited by SMDFlea; 06-11-2020, 05:53 AM.
Originally posted by SMDFlea View PostUse HP bios config utility BCU ,and/or wndmifit from windows or nbdmifit from UEFI flash drive . Use version 2.10 or above.
WnDmiFit 2.07 working properly - all data changed successfuly.
All done by creating pendrive in Rufus and used DOS version.
Source I faund here:
https://aiotutorials.wordpress.com/tag/wndmifit/
Thanks for help all.Last edited by Miquell210; 06-11-2020, 06:15 AM.
I am keep looking
Hello, I have an elitebook 9470m. I purchased a new motherboard and installed it. I have the error with the alert: "machine not in committed state"
I'm not sure how to go about fixing this, as I have read online many people have this problem with new motherboards. Windows boots and functions normally. Does anyone know if I can fix this with software? A new part is nice, but am I better off returning the motherboard for a used one?
okay, so I've used the tool, and I've learned that I now need 2 things; the "Feature Byte", and the "Build ID".
My own bit of research tells me that the feature byte is a long, case sensitive string of letters and numbers and it looks like this:
2U3E3X47676J6S6b727B7H7M7R7S7W7m7saBb3da.3Y
(this feature byte is for a ProOne 600 G2)
As for build ID...
I can't commit the board until I enter these last two fields! Does anyone know how I can find that info?
I have a 9470m i7 motherboard with HD+ graphics (1600x900)
also, classic bart mooning smilie? heck yes!
[QUOTE=Skunch;976137]okay, so I've used the tool, and I've learned that I now need 2 things; the "Feature Byte", and the "Build ID".
As for build ID...
Go to this site and enter your serial and country.With any luck the feature byte will be there.
https://partsurfer.hp.com/Search.aspx
Originally posted by Dragunbayne View PostDoes anyone have a newer NBDmiFit? I have a 450 G5 that I got a replacement board from HP for and I don't think any in this thread are new enough.
Originally posted by ala_borbe View Posthello
over the years i collected some versions of DMI tools for hp
and i wanted them to be all at one place
take note that some version are not correct (limited information, missing readme etc)
for some laptops you need older, for some newer but there is plenty here
also, you need to use this tool in dos
and there is Manufacturing Program Mode Error solution here since it is related to bios programming
enjoy and remember to share versions you have or related fixes
Originally posted by Shay_G View Postthere is a tool for hp 430 G6 ¿?¿
try 2.14
Originally posted by Aditya11ttt View Post
how to unlock my MPM¿,
please give me tutorial
https://www.youtube.com/watch?v=r2ubpyeUOB4
Read the pdf manual as well in the first attachment in this thread on page 1:
Manufacture Programming Mode in Unlock mode MPM
Originally posted by SMDFlea View Posthttps://www.youtube.com/watch?v=9T57ktw8n3Y
i want to do the opposite,
i want to change the value of my motherboard from LOCK to UNLOCK to change my serial number
MOD EDIT: NO dumps in this thread, Upload to the bios requests section: https://www.badcaps.net/forum/forumdisplay.php?f=40Last edited by SMDFlea; 08-21-2020, 02:04 PM.
