Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Many thanks all done ok confirm that works on x1 6th
      Hello Folk,please need help to remove password think pad youga X1 firt generation.
      thanks.
        thanks.
        Use the auto-patcher. Read the instructions and report the results.
        https://www.badcaps.net/forum/showthread.php?t=87588
        Thanks.
          thanks.
          try this file
            Thanks it's work!
              Anyone can be more specific how to use autopatch,any photo step by step or any video tutorial?Tanks
                The instructions are simple enough,why do you need step by step photos.
                  Couse I can't open autopatch.cmd
                    The instructions say you have to run autopatch.cmd from the command line,if you`re using windows.
                        I try to open with run administrator CMD and can't be open autopatch.cmd
                          Open the command line and navigate to the directory where your auto_patcher folder is.For example,if you have it on your C drive
                          cd c:\lenovo_autopatcher
                          autopatch.cmd
                            In that way I try. Open command line administratior cd.. cd..
                            Then I copy link from folder press enter and i'm inside directory,insert autopatch.cmd press enter then nothing happens.what other I can do after I all command I insert? Then I need to insert bios bin from CMD or what?
                              Ok I done,I understand what's the way.
                              Thank you
                                Thank you
                                autopatch.cmd path\to\bios.bin
                                  hi,
                                  why don't you integrate the Bios selection that I added? it's much easier to choose your file.
                                  Thanks again for your patch
                                    Originally posted by Maxpower3 View Post
                                    hi,
                                    THANK YOU FRIEND
                                    I WAITING FOR U BIOS MULTITOOLS
                                      hi,
                                      Because it only works on windows. I want the auto-patcher to work consistently across windows and Linux. Also leaving it more "lean" allows for easier integration with others tools (like you did).
                                      You guys are welcome to modify the base script as you see fit to make it more convenient for you to use.
                                        Originally posted by knucklegrumble View Post
                                        because it only works on windows. I want the auto-patcher to work consistently across windows and linux. Also leaving it more "lean" allows for easier integration with others tools (like you did).
                                        thank you bro for your great job
                                          Ok I understand your opinion.
                                          So for beginners, I made this new version which is easier to use.
                                          Only for Windows.
                                          Just install LENOVO DXE Auto-Patcher.exe
                                          And Click on desktop shortcut.
                                          Need Python 2.7.X
                                          Ps:"there is no interface for the moment, I have to finish the multi bios Patcher for that"
                                          For Windows 7 and 10 , 32b or 64b
                                          -------- Auto patcher with file selection V2 Version Mxp -------
                                          Special thanks to Knucklegrumble
                                          -Version Mxp:
                                          - Possibility to select your file directly
                                          - Auto-install with shortcut on desktop
                                          - Possibility of making several files in succession
                                          - With additionnal splashscreen
                                          Tested with version python 2.7
                                          Tested ok on W10 and Win 7(VM)
                                          Enjoy ,Test and Report please
