Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Try this and let me know if it works.
      I'll give it a try. I'll let you know, because I believe this post was directed to my earlier one.
      Thank you for taking the time to assist. I do appreciate it.
      EDIT: can you let me know the password required to extract it?
        For some reason I am unable to send you private message.
        Did not want others to use this file because it only works on your laptop. Password is ****.
          Did not want others to use this file because it only works on your laptop. Password is xxxx
          Edit post, got it.
          EDIT: I am trying it now, will let you know results soon.
            Can't even power machine up. Not sure what's going on.
            EDIT: putting original back on to confirm I can power it up again - which it was doing before I patched it. Perhaps this machine is not meant to be unlocked. I might have to let it go.
              It can be done, I am sure. I am just new to unlocking newer Lenovos so I might not have correct files yet. I have tested only on 4 different model right now (T440s, T450, X1 carbon gen 2 and X260).
              Maybe I needed to add that fingerprint driver aswell. I will send you another file later.
                Okay, sounds like a plan. Use the same password on the file I'll certainly give it a go, just putting original back on to confirm it boots. It should, reckon the patched bios was causing a problem.
                It's going to take a number of attempts I am sure. I've done it 3 times and all I got was the 5 beeps repeated so even my own attempts didn't quite work.
                  Originally posted by kerel View Post
                  hmmm, i cant enter private mail,
                  can you patch this bios file
                  can someone please patch this bios
                    private message blocked hhhhhhhhhhhhhhhhhhh
                      yeah i dont know why
                        Looks like the file I sent before should work..
                        *Remove all batteries (main battery and RTC battery).
                        *Patch the bios and make sure to verify it so there aren't any errors when writing.
                        *Hold down the small switch on motherboard
                        *Connect charger (laptop should start automatically)
                        *Wait. It might even take minutes and laptop will beep/restart a few times.
                        If it still doesn't work then sorry, I don't know how to help any further.
                          Thanks for your help in any case..
                            My private messages is blocked too. Why?
                            Can anyone write instruction post based on experience with x40, x50 series? I havent this laptop at now.
                              Blocked by many bad many
                                Blocked by allservice.ro
                                No problem i am working on lenovotranslateservice which will accpet any key
                                  You are focusing on the wrong part. Look a bit lower, outside of the box. There is an easier option to bypass.
                                    Hi guys
                                    Pleaseee share the lenovo translateservice file which will accept any key.
                                      Originally posted by przemek_79 View Post
                                      Hi guys
                                      I Can unlock your ntb for free send me your BIOS dump and model
                                        Well done! Did you find the spot I hinted or modified something else?
                                          I think i find the spot you mentioned about, i changed jmp short loc_64D to short loc_64F
