PCG-71316L does not turn on
    Hi
    PCG-71316L
    MBX-223
    this device does not turn on.
    PU19 gets hot. change it and hot gain.
    check ohm PL17 / PL16
    PL17 0.946k ohm
    PL18 25k ohm
    i took out PL17 and again checked ohm . side on the ic PU19 ohm 10k or above but other side(consumer) PC199 : 0.946k ohm
    when i enject 3.3volt in consumer side (PC199) for 1 second go high 0.18 amp and immediately 0 amp and not flow amp in circuit and not hot device .
    in last sorry about my english .
    tnx
    Re: PCG-71316L does not turn on
    Does PU19 get hot immediately after you plug in the charger or battery?
    Did you check other rails (+5VALW_LDO, +12V)? Maybe PU9 is short?
      yes when i plug charger pu19 immediately get hot.
      +5VALW_LDO not shorted
      +12 no shortd .
      just +3VALW show low ohm 0.945k(anormal). side of pc199 or TP219
        i enjected 3.3 volt in +3alw (pc199 or TP219) showing 0.18 amp for milisecond and go to 0 amp!
        somebody have any idea?
