Old 07-24-2020, 04:43 AM   #1
petehall347
City & State: worcester
My Country: United Kingdom
Default digihome ptdr24hds3 backlight only no picture
this one landed here . owner said he plugged in a lightening connector converter to hdmi then the picture and sound went off . i am wondering if its a firmware problem ?
from what i can figure out the voltages seem to be ok . i can check any again if needed .
what it does as soon as its plugged in is the standby light flashes then the backlights come on then it flashes some more and goes out . backlights stay on for a minute or so then go off .sometimes it goes through this 2 or 3 times on its own .all the while backlights are off there is a very quiet click sound from the speakers like its tripping . there is no response using the remote or pressing rear toggle switch/button
here are some pics .
Old 07-24-2020, 05:07 AM   #2
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
Default Re: digihome ptdr24hds3 backlight only no picture
digihome are quite good they have sent me the firmware in the past for a few sets
vinceroger69 is offline   Reply With Quote
Old 07-24-2020, 05:09 AM   #3
petehall347
i will look them up and ask them
edit ..
just looked and digihome seems to be just a name and the sets are made by vestel .did you mean i can get firmware from vestel ?
Old 07-24-2020, 05:21 AM   #4
vinceroger69
My Country: uk
sorry i just looked through my old emails it was http://www.umc-uk.co.uk/feedbackform.php who helped me not digihome maybe post in the fimware needed thread as some members seem too be able too help with vestel sets
Old 07-24-2020, 09:54 AM   #5
petehall347
i found this but cant figure out where to download the 2 files . https://translate.google.co.uk/trans...search&pto=aue
17MB211 17MB211S Full Software Installation Method:
the shredder_usb_update.b
shredder_usb_update.sc is
Copy the named files into the empty and formatted FAT32 USB stick.
Plug the USB memory into the TV's USB-1 port and while holding down the “ OK ” button of the remote control, plug the ac cable into the wall socket and hold it until the standby led starts to flash quickly.
Release the “ OK ” button when the standby led starts to flash quickly . When the standby led lights up, software installation process is completed.
As a result of this process, do not install " FULL " software with different serial numbers on the TV since the panel information will change !
Old 07-25-2020, 11:31 AM   #6
petehall347
i am wondering about the 12v supply as its at 11.3v . would this cause the problem ?
Old 07-25-2020, 11:46 AM   #7
diif
City & State: Midlands
My Country: England
Just above the comments there are 5 links, Vestel, Toshiba, Telefunken, Hitachi and JVC, they go to google drives, they won't work from the translate page, you have to go from the original.
diif is online now   Reply With Quote
Old 07-25-2020, 11:52 AM   #8
petehall347
yes i already have the core file . as i see it i need the other 2 files
unless i am being a bit thick here .?
Old 07-25-2020, 02:27 PM   #9
petehall347
well then ..just talked to the owner again and now he tells me the tv worked fine for 2 days after he had used the lightning/hdmi converter then one day wouldn't power on ..and he runs it off a modified sine wave power inverter . but had been fine for months .
he had it in his head it must be the hdmi converter that damaged it ..i dont think so myself .
Old 08-13-2020, 05:50 PM   #10
petehall347
righto i might have time to look at this again .if anyone sees this post i would like to know the test points to start with . i find it hard when the schematics are not in one .
