Any help would be appreciated. I'm not sure if i have t-con, main board, or panel issue?
Lg 65UH655O BARS ON THE SCREEN
Re: Lg 65UH655O BARS ON THE SCREEN
More likely to be panel.
You need to open up the back and see if the T-CON, tab bonding boards are on the bottom edge of the LCD panel or not.
Did anyone spray the screen with cleaner to clean the screen?Never stop learning
So can we see the backside of the TV?Never stop learning
So do you get picture just like in post #1 when both cables are back in place?Never stop learning
I had the same exact defect on a little older LG, it's a common issue on LG panels, the problem is on the source driver cof that began to slightly desolder, i have fixed it for some minutes but i had too much hurry to remount the bezel, the story is long, i ended cracking the cof due to shim mal positioned, its not easy when there is not a confortable plane of work. I think a better technique than mine can be used to fix it much faster and better with the use of a simple soldering iron stylus.
the other side should have shown a picture.
NOTE: A COF is a chip! not the band that holds it.Last edited by Davi.p; 08-08-2020, 05:20 AM.
Originally posted by gabe1022 View PostJust the home screen that was shown in the original picture. That is kinda what lead me to believe it wasn’t a panel issue. Thoughts?
!- BOTH ribbon connected
2- both side with one ribbon in placeLast edited by Diah; 08-08-2020, 10:06 AM.
