Hello, I repost the question in power supply discussions, because I guess it’s power component.
In the dead board (no power) of camera (Nikon D5), there is a chip with a hole. I can’t identify this component.
Horizontaly, that could be O60 or D60 or probably 060
I guess the marking code is :
060
A60
Y31
I found nothing on the web.
I can’t figure out what is this component ?
- It has no pin to ground
- I checked with meter : each pin is independant, there is no 2 pins both linked (like mosfet).
- It come after a big chip (1748 C3) but the same : I dont know what is it, I don’t found on the web. Maybe battery charging chip (edit : no, the battery charging with external charger) ?
- It is close to a chemical cap and other big ceramic one
- It is close to the connector of command buttons and small (band maybe big other ?) LCD display (on the back of the camera). But maybe there is no direct link.
- there is 2 buck converter (2 chip PA61), I marked with a black « B » (for buck) on picture. One go to CF-card board.
Do you know what it is pls ?
At least, do you know wich smd box is ? I guess SON …
Tell me if other info could be usefull pls ? I can measure or add picture. I dont have yet disassemble the board, but I can.
060
A60
Y31
