Bios dump for Dell Optiplex XE?
    Hi, does anyone have a bios dump for this model? or a method to extract the BIOS from the dell website? Thanks!
    Re: Bios dump for Dell Optiplex XE?
    http://downloads.dell.com/published/...tiplex-xe.html
      Thank you!
        Can anyone extract bios bin from dell site bios????
          Here
          Become a Badcaps supporter
          Thanks to all supporters.
            Originally posted by hoaca388 View Post
            Here
            Will u share how u did it pls????
            With wich soft????
              Use writeromfile command in cmd. For example, we have a file A05.exe -> A05.exe -writeromfile, the result is a file A05.rom.
                Its the wrong size though.You need the backup to compare it against and then youll know where to cut,edit or merge it.
                  Yes sir, U r rite its size is wrong but amazingly its working with wrong size 1984kb instead of 2048, i check only display may be it create probs afterward.
                  so now i should compare it with old bios???
                  compare with which soft???
                    use writeromfile command in cmd. For example, we have a file a05.exe -> a05.exe -writeromfile, the result is a file a05.rom.
                    ty
                      I was also surprised at its size but I thought it might have to be some part of the original file but I don't have the original file to check.
                        This one original backup
