HP EliteDesk 800 G2 Small Form Factor PC bios request
    hi...HP EliteDesk 800 G2 Small Form Factor PC bios and ec needed...i will send the copy of main bios and ec and a 9meg bin file that extracted from hp recommended file for the serial number of this pc...i dont have the knowlege to create a working file from orginal file...also i checked the same requested bios forums for this model tought may working for mine to but they didnt...with my orginal corrupted bios cpu detect and get warm but with those files cpu did not detected...thank you for sharing
    Re: HP EliteDesk 800 G2 Small Form Factor PC bios request
    Originally posted by soso technician View Post
    hi...hp elitedesk 800 g2 small form factor pc bios and ec needed...i will send the copy of main bios and ec and a 9meg bin file that extracted from hp recommended file for the serial number of this pc...i dont have the knowlege to create a working file from orginal file...also i checked the same requested bios forums for this model tought may working for mine to but they didnt...with my orginal corrupted bios cpu detect and get warm but with those files cpu did not detected...thank you for sharing
    try..
      Originally posted by peste View Post
      try..
      thank you so much peste for your help and spending your time for solving the problem....it worked perfectly.
        hi... I need help,
        I have HP EliteDesk 800 G2 SFF, can I reflash the EC and Main BIOS by using dump files for another machine?
          Originally posted by mradouane1 View Post
          hi... I need help,
          If its the same exact machine yes,but if its an intel based machine then the ME management engine firmware would need cleaning before flashing the bios.
          On some boards the MAC address is also unique to the machine so its better to try and fix your bios first.
            Thank you,
            its same machine, I'll cleaning the ME Region and trying to reflash again (EC and MAIN)
              s
                how do you do the engine management cleaning if the computer refuses to post. The fans spins very fast. That is all I get.
                Here are my files.
                  Anyone can help? Thank you
                    Anyone can help to get a clean bios?
                    Fan spins and theb end up spinning very fast. Not post after bios update. I tried to flash the bios with the hp latest file but still doesn't work. I think my ec controller bios needs cleaning. I posted it my files a few posts ago.
                    Thank you
                      Thank you
                      posted bios are corrupt EC is empty, and main half empty ... extract once more and post, check before posting the bios in HxD program ..
                        Oh thank you. Could it be corrupted and empty from the update?
                          My problem started when I tried to flash the main bios. I think I interrupted the process by mistake and now it wont post.
                          The file I've added below is the main bios from hp's website. I just tried to useit again (After the flash, it booted with no post but nothing was happening except the fan spinning and then when I turned it off, it ended up making 2 long beeps and 4 short beeps and then powering itself back on. After powering itself back on, it still woudn't post and the cpu fan would gradually spin faster and faster until it reaches it's top speed) I also tried the solution from peste that worked for the original post of this thread. Nothing worked, same problem but no beeps, the cpu fan just spins quickly after a minute or so. I am using the software XTW2 Programmer with the XTW 2 usb programmer. I can even remove the ram and the computer will do the exact same thing. No beeps. Just a fan that spins very fast after a minute.
                          Here is a picture of my motherboard.
                          https://drive.google.com/file/d/1xDh...ew?usp=sharing
                          The yellow chip is obviously my main bios but is the red one the ec bios? It looks like it because they are the only ones that I can put the clamp on.
                          Does someone has a clean bios for the ec for the 800 g2 spitfire rev A?
                          Thank you to anyone that has an idea and can help. Otherwise, I think I might need to buy another motherboard even if this one is potentially fine.
                            Sorry, I forgot to try to extract it again before I flashed it with the bios from hp's website. I think it was corrupted anyway. How do you check in the program hxd? I opened the file. I don't have the original bios file from my machine anymore. It's been corrupted that's why it's not working.
                              try post # 2 ..
                                try post # 2 ..
                                I did
                                  I did
                                  Flash the 8MB from post #1 and the 16MB from post #2 .
                                    Not on the same chip right?
                                      No, 2 seperate chips. If both bios chips are macronix then MX25L12873F = 16MB, MX25L6473F = 8MB .If they`re a different brand such as Winbond they should have 128 and 64 as part of the part number,such as 25Q128 25Q64
                                        They are exactly the first 2 that you mentioned. I am having a hard time flashing the 8mb with my clip. I need a better clip.
