I've got a viewsonic vt2430 that basically won't turn on. It will go from stanby to on and show the viewsonic splash screen the back off and repeats forever. You can't turn the tv off either once its doing this cycle, you have to pull the plug from the wall. Doing a breif google search alot of people are having this issue but i haven't came across a solution yet.
When i opened it up to check the power supply it has 2 types of caps. Elite and Her-Mei
I removed every capacitor and checked the esr and capacitance and they were all 0.00 and the capacitance was well within the allowed 20%. I did however find 2 caps (22uf &47uf) that the esr was .4-.5ohm. I swapped them out with a couple panasonic fc's i had in my box-o-stuff that the esr was 0.01-.06
The 22uf cap is the startup cap and the fc that replaced it had an esr of .01.
The PWM controller is a Green-Mode PWM Controller with High-Voltage Start-Up Circuit and Adjustable OLP Delay Time (LD7576PS). When i checked ground to all the other pins, most were in the k-mohm range but i did find pin 4(ground) to pin 3(CS, Current sense pin, connect to sense the MOSFET current) to have a reading of 98ohms. Now would this be an issue causing the PWM controller not to start up completely? I did do a voltage check at the startup cap amd it was 20.86v-21.22v. It slowly rose then fell back when the blue led went off then back on when its doing its repeat cycle.
I haven't checked the caps on the main board yet. I am unsure if this type of issue would be the power supply not turning on due to a fault or the main board telling the power supply to cycle. Here are a few pics of the main board and power supply.
