Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 04-15-2020, 06:01 AM   #21
Rich2371
City & State: Leicester
My Country: United Kingdom
I'm a: Knowledge Seeker
Default Re: Troubleshooting B&W Original Powersupply
Hi just joined this forum, I need help with an Zeppelin ( early MK1) my Red led is on not flashing, I've replaced all six caps ( two showed signs of stress outer casing s wrinkled) but it still the same just a constant red led on (Stuck in standbye)? Checked all three fuses all ok�� .
Any ideas please, thanks��
Rich2371 is offline   Reply With Quote
Old 11-14-2020, 12:09 PM   #22
SilEng
City & State: Honiton
Picked up a B&W Zeppelin for free last night and was told it had stopped working although it lights up but shows the red flashing LED. After following the guide I found the 47uF 400v and 2200uF 16v caps swollen, ordered up a full set of Panasonic FR caps for 12 and going to see if I can get it going.
I'll keep you posted on whether its operational at the end of the next week.
Thanks for your write ups and advice, most helpful.
SilEng is offline   Reply With Quote
Old 11-17-2020, 03:29 PM   #23
SilEng
Hi again,
I took the opportunity to replace all 6 caps with Panasonic FR types and paid princely sum of 12, it took no more than an hour to repair. It's now working again and sounds great, for a freebie I cant complain. Just need a blue tooth dongle and add some new fabric over the speaker grills to make it mint again.
I am a little gutted as my son has pinched it for his room.
Old 01-22-2021, 04:03 PM   #24
OmidN
City & State: Paris
My Country: France
I came across this forum and it seems it the only good help on the net. I had the same issues and I decided to follow the instruction to open my speaker, but when I reached PSU it doesn't look evident to me. Maybe the yellow one?
I appreciated it if someone could help.
OmidN is offline   Reply With Quote
Old 01-22-2021, 05:51 PM   #25
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
strange,
the 4 diodes - D201 etc look like they have burned/corroded leads.
stj is offline   Reply With Quote
Old 01-23-2021, 03:47 AM   #26
OmidN
City & State: Paris
My Country: France
Hi Stj,
Many thanks for your quick reply, so do you think i would change them first and give it a try?
could you please let me know the model and the details of the 4 diodes to purchase?
Sorry I don't have electronic background , I am just trying to avoid throwing electronics
Thanks again
Old 01-23-2021, 04:13 AM   #27
stj
stj's Avatar
test them with a meter
Old 01-23-2021, 04:25 AM   #28
OmidN
City & State: Paris
My Country: France
Thanks for your help and prompt reply.
I should find a place to test them since I don't have the meter.
When i looked closer it doesn't seem to me that they are burnt, maybe it was the photo.
PFA a better photo
Old 01-23-2021, 06:37 AM   #29
stj
stj's Avatar
if you dont have a meter then how can you fix anything?
Old 01-23-2021, 08:33 AM   #30
OmidN
City & State: Paris
My Country: France
Yes you are right, I thought if I can find the problem I will go around and ask someone in the electronic repair shop, but anyway I am going to buy the meter and soldering kit to be independent!
Old 01-25-2021, 08:03 AM   #31
OmidN
City & State: Paris
My Country: France
Hello Stj,
I have check the diodes D201, all 4 seems to be good, on the good direction they are reading around 470 and opposite OL.
on the other hand I touched the surface of the capacitor in the photo, it seems bulged, I also see the one behind is a bit bulged, as far as I understood from this forum I have to order 4 capacitors below:
Rubycon ZLH 2200 uF 16 VDC
Rubycon XYG 470 uF 16 VDC
Rubycon ZLH 220 uF 35 VDC
Rubycon ZL 1000 uF 35 VDC
could you please advise?
Old 01-27-2021, 11:02 AM   #32
OmidN
City & State: Paris
My Country: France
Any advice please?
Old 01-27-2021, 11:52 AM   #33
stj
stj's Avatar
bulged caps are bad.
it means the liquid in them has boiled or generated gas.
Old 01-30-2021, 03:44 AM   #34
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Quote:
Originally Posted by OmidN View Post
Hello Stj,
Yes I was going to say they look bulged in your first pictures...
Replace them and see how you go...
__________________
Per Hansson is offline   Reply With Quote
Old 02-01-2021, 03:49 AM   #35
OmidN
City & State: Paris
My Country: France
Many Thanks, I will keep you updated, I am ordering them through https://fr.rs-online.com/web/ca/recapitulatifpanier/
Just for the record in case if anyone else need that in future
Old 02-05-2021, 04:43 PM   #36
OmidN
City & State: Paris
My Country: France
Many thanks for your feedbacks, I changed those 4 caps and my speaker is back to live. I appreciate it, A few comments for the next person:
1. I have damaged the seat for PSU, basically I tried to screw it back gently but somehow all the seats damaged. The plastic became brittle. I eventually managed to fix 3 of the screws so PSU doesn't move.
2. Please look at the disassembly a few times before you start opening, I damaged the locks for the front cover. now the cover is not 100% fixed in its place.
3. In my order the 470uf caps were a bit fatter than the original one, so I was struggling to solder it in its place.
Old 02-05-2021, 08:25 PM   #37
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
If you have access to plastic spacers or plastic square bar and the right length screws and square bar would probably be the best thing to try or metal “L” bracket screw one side of the “L” into the cabinet and the other side of the cover if you have access to treaded rivets mount them on the side of where the cover is being mounted to the “ L” bracket
I have done this many times in the past when the original plastic pin break use plastic spacers and screws in place of the broken plastic pins or if you have access to circuit board stand-off is the best solution for this type of problem
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
