Dell Inspiron 3593 (Not Charging The Battery)
    Can anyone please HELP.
    I have a Dell inspiron 3593 (FDI55 LA-J081P) REV:1.0 (A00)
    The battery does not charge it Identifies the Chargers 65w and 90w but as soon as I connect the battery it says (AC NOTinstalled and Starts Discharging the battery)at one point it would charge then after 2 min go to IDLE.
    I have tried the following.
    1. Flash with different Bin files
    2. Changed Batteries with known Good ones
    3. changed charging Jack
    DCIN 19v
    PSID 3.0v
    Please Help.
    Re: Dell Inspiron 3593 (Not Charging The Battery)
    Remove all power -> meter in resistance mode -> check the usual 2 x DCin mosfets to see if they are defective or not.
      need schematics !
      test PR1 if 33 ohm or not
        need schematics !
        https://www.badcaps.net/forum/showth...light=LA-J081P
          SDA/SCL present on charging chip?? If you have DSO, check communication on SDA/SCL lines.
            sir if the communication shows, does it mean that all charging circuit, i.e its IC, Caps, Resistors, Mosfets are OK or we should explore/test further.
              SDA/SCL communication is just one part of troubleshooting a charging circuit. You simply cant ignore the other aspects. This communication cant rule out other faults.
                ok got it sir,.,.regards.
