Lenovo 320-14 320-15 320-17 520-15 B320-14 V320-17 BIOS
    Re: 3Lenovo 320-14 320-15 320-17 520-15 B320-14 V320-17 BIOS
    Originally posted by ScotchArg View Post
    Can u extract this for me?
    Here
    Become a Badcaps supporter
    Thanks to all supporters.
      Re: Lenovo 320-14 320-15 320-17 520-15 B320-14 V320-17 BIOS
      that's not a file of 8mb valid
        Ofcorse, you need combine that file with your original bios file to rebuild a new one.
          I have now an 320-15IKB Type 80XL but with the bios of first post I ave 30 seconds to POST.
          This is the dump
          Thank you very much
            This is the dump
            Thank you very much
            The file you posted is not the original file, it has no DMI.
              Maybe you are right. I will try and post results. Thank you!!!!
                I have a problem, none of them work, this is original
                  Post the serial number and Model Type thats on the case sticker
                    thanks for the quick response
                      520-15IKB (Type 81BF) Laptop (ideapad) - Type 81BF
                        unfortunately not working, black screen
                        when turned on, the power indicator and the power indicator below the power button come on. the keyboard lights up, everything goes off.
                        I press the switch and the keyboard lights up, the fan starts, after the chili the fan starts to work at higher speed, the screen is black
                          If after 15 minutes it shows no other improvement then you don't have bios error. Look for other hardware causes.
                            thanks
                              Muchas Gracias Colega.. Thank you colleague
                                i have this model 520-15IKB (Type 80YL) i programmed the 8192kb file on the bios chip.
                                But the 128kb ECrom file cant find the chip can someone tell me where too find it?
                                  the EC file is in the I/O chip..
                                    I do have svod3 programmer but i see ony nuvoton , ene, ite but no lenovo.. can i trie too program it with one of those.,??
                                      I haven't worked with this programmer... maybe someone else can help you... the bios you need is in post #1... don't forget to make a copy before writing...
                                        Thank you!
                                        Mohammed Mohan
                                          can any one send it8586e ene sio programmer pin configuration
