Asus X540UB no vcccore
    Model :Asus X540UBR
    M/b: NX540UBR Rev 2.0
    Problem: turn on when PSU cable is inserted, consumption 0.106 amp .No display.
    Observation:
    1. No liquid spill or corrosion observed.
    2. 3v/5v alw present.
    3. 1.2/+vtt/+2.5v present
    4. 1.0VSUS present
    Diode mode value :
    Pl 8901 = 05.16v
    Pl 8701 = 0.354v
    Pl 8702 = 0.258v
    pl 8600 = 0.358v
    Pl 8302 = 0.059v
    Pl 8103 = 0.007v
    Pl 8102 = 0.007v
    Pl 8101 = 0.011v
    Pl 9101 = 1.030v
    Pl 9100 = 0.030v
    So No vcccore , no +nvvdd , no vccgt , noFBVDDQ.
    I have flashed Main with official dump,still same.
    All power sequence voltages are present until PLT_RST ; No DDR4_DRAMRST is observed.
    Can we confirm that :
    PCH or CPU is faulty !!
    OR is there any others measurements that must be taken...thank you.
    Re: Asus X540UB no vcccore
    With Asus always check powergood signals.
      First, you can't have 1V at PL9101 in diode mode and almost nothing at PL9100 at the same time. It's just another phase of the same rail.
      Second, except measuring data rails, it is usually a bad idea to check power rails in diode mode because it is hard to compare caused by the difference of this function in the various existing multimeters. Ohms mode would be way better for that. Maybe you can add these values.
      And like mcplslg already told, check at least Powergood from the VRM and RAM supply and if there is something suspicious, you need to dig more deeper from there.
      FairRepair on YouTube
