hp 15s-fr2xxx
    hp 15s-fr2xxx
    this laptop cant shut down . it boots by itself 2 seconds after shutdown . i need solution .
    part no. DA0P5HMB8F1 rev f
    serial number. 5CD1409DJV
    Re: hp 15s-fr2xxx
    Go to the HP support site,enter your serial number.Download the bios update and run the exe. It will give an option to make a recovery USB drive or you can choose to save to a location.If you choose to save to a location all the bios will be decrypted and saved. If there is only one bios then that is what you can use.If there are multiple then you need to know which one to choose. Open your bios backup (if you have one) with a hex editor and search for the file names, sometimes they start with the word BID .You can flash the virgin bios but you will lose all DMI info.If you have a backup its relatively easy to copy all the info from the backup to the virgin bios with a hex editor,it will take you less than 5 minutes from downloading,extracting and copying the DMI.
      Re: hp 15s-fr2xxx
      tHank Sir. i have tried this but still reboot while shutting down. is there any way of solving this problem
        Re: hp 15s-fr2xxx
        post your old dump
          Re: hp 15s-fr2xxx
          Originally posted by lapfix View Post
          post your old dump
          THank you for your response . piease here is the file
            Re: hp 15s-fr2xxx
            HP Laptop PC 15s-fr2000-087FD ( Use the remaining rar file if ...-087FD does not work.)
            Become a Badcaps supporter
            Thanks to all supporters.
              Re: hp 15s-fr2xxx
              tHANK YOU SENIOR. I have tried them all , all of them works but still cant shutdown. instead of shutting down, it restarts. it turns on 2 seconds after shutdown. what must i do again?
                Re: hp 15s-fr2xxx
                not a bios issue.
                  Re: hp 15s-fr2xxx
                  Probably some kind of short on some S0 rail.
                  I don't provide help for people using CH341A and a clip.
                    Re: hp 15s-fr2xxx
                    try this one. if it doesn't work, maybe its an EC firmware problem of bad SIO.
                    all donations are welcome,
                      Re: hp 15s-fr2xxx
                      Thank am gonna try . i will reply after
                        Re: hp 15s-fr2xxx
                        i tried but still boots after shut down
                          Re: hp 15s-fr2xxx
                          not a bios issue.
                          please what might be the couse?
                            Re: hp 15s-fr2xxx
                            Find hardware support here : https://www.badcaps.net/forum/forumdisplay.php?f=23
                              Re: hp 15s-fr2xxx
                              Open a thread in troubleshooting section and will try to help you.
                                Re: hp 15s-fr2xxx
                                thank you
