I did change the t-con and it goes to protect mode green and orange ligth comes on blinking....i press on power button and plug while holding power button and its start on arrow circle around cycling and stays there for ever...
Sony KDL-70W850B T-CON problem
Re: Sony KDL-70W850B T-CON problem
Do you have to pair the Tcon to the mainboard. Diah and Neilc6 may have some information on this that could help.Last edited by dick_barton; 01-22-2021, 03:38 AM.Willing to help but I'm no expert.
T-CON replacement dont need any pair at this sony. the T-CON must be 100% for the same model and screen size.. but if the original are defect and it register 5 blinking error ,, then need to clear the error at self diagnose service menu..pairing and adjustments need only if Main boards or tuner replaced..
so..
why you changed the T-CON ??
put back yours yours original T-CON in place and turn on to let the set running normal again..... and show us clear photo on the boards and the issue you have.Last edited by Diah; 01-22-2021, 01:08 PM.
The problem of the tv with original t-con is that when tv is turn on works great all day once its to be turn off you cant turn it back on it gives green and orange ligth...i need to unplug it and it will turn on good until its turn off....so did change t-con new and does not come on green and orange ligth
Originally posted by hmendez86 View PostThe problem of the tv with original t-con is that when tv is turn on works great all day once its to be turn off you cant turn it back on it gives green and orange ligth...i need to unplug it and it will turn on good until its turn off....so did change t-con new and does not come on green and orange ligth
firmware start script when the set turned off, there are low RESET at the chips where forced the start script start from beginning. so the set will turn on normal again as last state before it turned off. if this small procedure interrupted because of bad chip ( sector) or there were bad caps which didn't discharged as it need so the chips ( start script i mentioned above ) remain active and didn't reset it self. until the currents drops close to ZERO.
i asked you at my post #6 to put back yours original T-CON so we can start diagnose the issue.. but as usual many just they believe on what they have in mind.. on this way i cant share my help.
Hi Diah
Have a few questions , if you don't mind .
Is this one of the earlier Sony models , that use the Linux operating system ?
Is it the later Sony sets using the android operating system that are more particular , with regards to pairing ?
Thank you in advance , Zen.
Zen, asking questions is great but you need to start your own thread. If someone stops to answer a bunch of questions in the middle of someones thread, it only takes longer and adds confusion and unnecessary length to the thread. I'm pretty sure Diah knows the answers but this particular thread is for the task at hand, trying to fix this tv. Not that I really care what goes on here, it's just a little distracting.Last edited by nomoresonys; 01-23-2021, 05:40 AM.
But before did the update the backlight were working...first i put the usb with update then i connected to outlet and started alone updating and backligth on with the circle arrow doing his update when it finished turn on and off then back on but with no backligth...but i can see the image with flashligth now it stays green ligth...
