Lenovo 500-15isk LA-C851P without CPU voltage
    Lenovo 500-15isk
    LA-C851P
    i measured all voltage, only cpu dont work
    there is NCP81208 chip for three rail voltage :
    VCC_core VCC_GT and VCC_sa
    only one of three voltage working .ist 1volt
    two voltage ist null . i replaced 81208 chip ,but dont change. also i chnaged two NCP81253 together, one have voltage another ist null. also dont change
    So i think 81208 and 81253 not defect and problem ist another place.
    i can see three pin Communication (SOC_SVID_CLK ,SOC_SVID_DAT,SOC_SVID_ALERT) that connected direct to cpu .
    any person have idea for my problem ?
    How one of three voltage rail working , because all enable pin ist same but with seperate PWM ?
    i dont found datasheet for 81208 but i thinks ist similar NCP81243
    Re: Lenovo without CPU voltage
    Chek all your pgood pins
      i checked
      i am sure that +VCC_SA(one of three Rail voltage for NCP81208) ist ok ,plus VR_PWRGD
      Also i think +VCCIO is good.
      Have an idea?
      i reprogram Bios with this file.maybe my problem ist Bios ???
      please check my bios
        No one can help?
          I got your PM. Try this bios.If it doesn`t work keep testing .
            Looks a lot like 2015! So an absurdly short life before a failure!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            16 GB AData XPG Spectrix D41
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              thx for reply
              i reprogram, now i have VCC_core(1 Volt clear) without VCC_GT.
              i think my problem ist Bios
              in addition, my Bios chip isn't 25Q64 . ist 25Q064A13. maybe ist important
                Do you can modifying my bios program ?
                with your Bios ,VCC_Core working only VCC_GT dont worked
                i am sure that dont have hardware problem
                  VCC_GT here refers to GFX Core ?? If so , it can be missing coz of many reasons like Bad bios, Bad ram stick or slot, PCH, Vcore ic(i rule it out as you have already replaced it) and missing DRAMRST# signal.
                  I'll suggest to check DRAMRST# signal on pin30 of Ram Slot. It should be 1.3V approx.
                    Originally posted by mcplslg123 View Post
                    VCC_GT here refers to GFX Core ??.
                    i thinks No, because i have GFX voltage
                      ok. I didnt looked at the diagram. Just thought of it. Thanks for correcting.
                        Update :
                        today i checked again, i can see when press start button,The LCD turns on and gets darker but without backlight
                        can i connect "VCC_Core" Enable pin to "VCC_GT" Enable ?
                          did you solve the issue?
                            Yes,After reprogram Bios,and without VCC_GT, i changed a lcd cable and working
                              If I am getting it correctly a bad LVDS cable was causing VCCGT to be missing?
                                https://logi.wiki/index.php/User:Pie..._I_solve_it.3F
