Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Thread Tools Display Modes
Old 04-16-2021, 01:45 PM   #1
ay_erdi
City & State: istanbul
My Country: turkey
Line Voltage: 220VAC 50Hz
I'm a: Knowledge Seeker
Default Seagate ST500LT012 Problem
I have this model HDD.Hdd connect to via usb 3.0 hdd tool,power on spinning drive and hit the head power off.
I removed the hdd's motherboard,test the capacitors,resistors etc.
in the red circle capacitor short circuit but I removed both of capacitor on motherboard everythink normal.
I not find the board schematic.I need to helps.
I have similar to three HDDs.
TOSHIBA MK5055GSXN no power.
TOSHIBA MK3276GSX
SAMSUNG HMUI no power.
Should I open a topic,separately for these HDD's or should I continue with this topic ?
ay_erdi is offline   Reply With Quote
Old 04-16-2021, 03:42 PM   #2
dicky96
Sun Seeker
dicky96's Avatar
City & State: Sunny Gran Canaria
My Country: Spain
Line Voltage: 220V 50Hz
I'm a: Professional Tech
Default Re: Seagate ST500LT012 Problem
Does it spin up, go click click (heads moving) then power off?
dicky96 is offline   Reply With Quote
Old 04-16-2021, 04:11 PM   #3
ay_erdi
My Country: turkey
Quote:
hi dicky96
yes yes exactly
Old 04-16-2021, 05:11 PM   #4
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Hell's Front Porch
My Country: USA
Line Voltage: 120/2/[email protected]
I'm a: Hardcore Geek
Quote:
Originally Posted by ay_erdi View Post
hi dicky96
yes yes exactly
The drive has failed. If the data on it doesn't matter, destroy the platters (warning: glass platters!) and dispose of the remains in any way you see fit. Otherwise, reinstall the controller PCB and send it to a data recovery company. (ACS, DriveSavers, Gillware, etc)
__________________
Windows 10? Only if you like forced, buggy updates and 24/7 telemetry.
Samsung = Seagate = Seatrash = Trashgate
Don't buy Seagate drives. Don't use Seagate drives. If you have any in service right now, make plans to replace them ASAP.
SMR = Slow Magnetic Recording
Avoid SMR, buy CMR drives instead. SMR is easily a 15+ year step BACKWARDS in HDD speed.
Permanently Retired Systems:
TechGeek is offline   Reply With Quote
Old 04-17-2021, 03:51 AM   #5
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
I second what Tech Geek says
I have a 2Tb seagate that has the same problem. I read a forum post somewhere, where someone had exactly this, and he bought a replacement controller board - they are easily available on aliexpress or ebay. The next step is to desolder the BIOS chip from the original controller board and fit it to the new board. Finally fit the new board.
In his case he claims it then worked
I tried exactly the same (mine was an identical model HDD) and in my case it made absolutely no difference - spin up - seek -seek - power down.
So you could consider that 50/50 and maybe give it a go but from my own experience I wouldn't hold my breath.
Rich
Old 04-17-2021, 05:26 AM   #6
ay_erdi
My Country: turkey
Hi friends,
I want to repair it myself this hdds.I guess nothing can be done.
Thanks for your help.
Old 04-24-2021, 10:45 PM   #7
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
If the HDD spins up and clicks (head seek) but cannot initialize properly afterwards, then it's probably a failed head on the headstack or buffer amp on the headstack assy. So in that case, you could try to swap the headstack with another one from the same model HDD... but that's really only worth doing if you have valuable data on the HDD or just if trying to learn to do data recovery from a failed HDD.
Otherwise, just as a repair to get a working HDD, it really isn't worthwhile.
Quote:
I honestly see no reason to try to destroy non-working HDDs in personal PCs. People must be watching too many movies to have that kind of paranoia. If you just chuck the HDD in the trash / recycle bin / e-waste collection site as-is, it will be fine. No one's going to take an unknown HDD and spend 10's of hours (if not more) to try to recover data off of the HDD in hopes of finding sensitive information for profiting (CC numbers, identity, and etc.) It's too much effort, especially for an HDD from a personal PC. Now, if it was some HDD from a large multi-million corporation, that might be a different case. But even then, even if there was any sensitive data on there, you'd have to get around any possible file-encryption methods that the company could have used with a software on their HDDs. So in the end, even such HDDs may not be worthwhile to bother with.
So the whole "destroy the HDD so someone doesn't steal your data" argument is just unnecessary paranoia, IMO.
Old 04-29-2021, 10:40 AM   #8
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
@momaka
how does one go about changing the head stack? step-by-step if possible. Just for the purposes of learning to do data recovery, it sounds interesting, if not down right fun
__________________
Follow me on YouTube
Learn Electronics Repair
Old 04-30-2021, 04:19 AM   #9
TechGeek
Computer Geek
TechGeek's Avatar
My Country: USA
@momaka
Here's a simplified process:
1) Remove drive cover.
2) Install jig to protect heads.
3) Remove top head stack magnet.
4) Unscrew connector that connects head stack to the controller board.
5) Unscrew and remove head stack.
6) Repeat steps 1-5 for donor head stack.
7) Install and screw in donor head stack.
8) Screw in connector from donor head stack.
9) Reinstall top head stack magnet.
10) Remove jig.
11) Reinstall drive cover.
12) Connect drive to computer running specialized software.
13) Build head map and recover as much data as possible. Note: Head 0 is critical. No Head 0, no data recovery.
Old 04-30-2021, 05:02 AM   #10
diif
City & State: Midlands
My Country: England
@momaka
This guy has some excellent videos on swapping the head stack. The tools can be bought on Ali, search for head comb.
https://www.youtube.com/channel/UCso...uw4Odm6MyBXLmg
diif is online now   Reply With Quote
Old 05-01-2021, 04:34 AM   #11
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
Thank you very much guys
You now how much I like to play wi....... errmmm I mean experiment with.... this sort of stuff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
