Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 03-03-2022, 08:32 AM   #1
jayjr1105
jayjr1105's Avatar
City & State: Central PA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default 9v super basic wall wart issue
This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output.
__________________
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%
jayjr1105 is offline   Reply With Quote
Old 03-03-2022, 01:38 PM   #2
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
I'm a: Hobbyist Tech
Default Re: 9v super basic wall wart issue
power supplies tend to have minimum load, does it surge with some load?
eccerr0r is offline   Reply With Quote
Old 03-03-2022, 01:49 PM   #3
jayjr1105
jayjr1105's Avatar
I'll check later tonight
Old 03-03-2022, 03:56 PM   #4
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Replace that small electrolytic C3
R_J is offline   Reply With Quote
Old 03-03-2022, 07:44 PM   #5
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Look if C3 has something to with the feedback and change it.
CapLeaker is offline   Reply With Quote
Old 03-03-2022, 08:56 PM   #6
R_J
City & State: ☻
My Country: Canada
I wonder if C3 might be the issue
Old 03-03-2022, 09:04 PM   #7
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
My Country: USA
The 431 may be hunting.
Try a 150-1k resistor across the IR LED in the opto.
Points are marked in attached image.
Change the small cap on pri side to 22u/50v or 47u/50v.
__________________
"pokemon go... to hell!"
EOL it...
Quote:
Originally Posted by shango066
All style and no substance.
Quote:
Originally Posted by smashstuff30
guilty,guilty,guilty,guilty!
guilty of being cheap-made!
kaboom is offline   Reply With Quote
Old 03-03-2022, 09:04 PM   #8
jayjr1105
jayjr1105's Avatar
I pulled all caps one by one and they all checked out. I can replace it anyway but don't know what good it will do
Old 03-03-2022, 09:37 PM   #9
jayjr1105
jayjr1105's Avatar
9.21v stable. How do I know which one fixed it? Replacing C3 or adding a 330ohm resistor to the opto?
Ok, pulled the resistor off and it's still good. Pulled C3 which was a 10uf 50v cap and replaced with a Panasonic FC 47uf 50v.
Old 03-03-2022, 10:53 PM   #10
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
My Country: USA
Soldering heat from R&R'ing C3 may have temporarily "woken" it up.
The 431 seems to need a minimum load; when an unbypassed opto LED is the sole source of current to the 431, the latter can hunt.
Leading to voltage "bounce" at no load.
Perhaps it was C3.
With the original C3 in place, leave it out in the cold a while- it'll probably act up afterwards= cap(s) is/were suspect.
In similar SMPS wall warts, I've used 22-47u/50v caps, PW/HE/FC, for C3.
If a new C3 keeps it stable, even cold, you can probably leave the opto LED unbypassed.
Old 03-04-2022, 08:50 AM   #11
jayjr1105
jayjr1105's Avatar
Perhaps it was C3.
The 431 is the small voltage reference SOT23 part?
Old 03-04-2022, 05:15 PM   #12
jayjr1105
jayjr1105's Avatar
BTW, got home and still tested very stable around 9.2v.
Old 03-04-2022, 08:01 PM   #13
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
glad you got it fixed! I ran into a similar issue before on a different power supply where it only supplied half of the voltage.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
