Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 02-24-2022, 11:42 AM   #1
Danny75
City & State: Dordrecht, South-Holland
My Country: Netherlands
I'm a: Knowledge Seeker
Default Mtester
Hi all, new here and wanted to ask you guys if you can help me understand the device I got.
A few years back I got this Mtester at a local shop but noticed that it sometimes seems to have some errors?
Secondly, I would like to understand how this thing works when for example testing caps, if it needs some kind of calibration of some sort.
The error it seems to give is that when I measure a (used) electrolytic cap and place the leads in socket 1 and 3 it sometimes displays that the cap has zero ESR (ESR reads 0.00) But when I place the same cap into lets say socket 1 and 2 it does display a certain ESR value. Have noticed this happening several times.
I was at that shop and saw the man sell this device to someone and heard of its capabilities and got interested too. So I bought one, not knowing what it was exactly, I mean I did not know that i could be a copy of an original Mtester, still not sure though.
The reason I ask is that I have been given some boxes filled with used and old stock caps and have already gone through some of it to see whats good and what not. Well, that is the thing, some were obvious as they gotten a capactiy of over three times or more of their original size. Others had such a immense large ESR that that was an indicator too as some similar ones (of the same value, type and brand) were still in spec.
But is there a guideline to see when a cap of a certain value is probably out of spec and gone bad?
Danny75 is offline   Reply With Quote
Old 02-24-2022, 11:55 AM   #2
Danny75
Default Re: Mtester
This is my little tester and some of the caps I got.
Strangely enough some of the top tier brands were completely out of spec and some brands that I haven't heard of before like Tosin were perfect. But then again, it is not known where those caps were used and if they had a hard life or not.
Some of you may not agree reusing used or salvaged caps but I think when they are in spec and still seem ok, why not
Old 02-24-2022, 01:04 PM   #3
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Mtester
it's a T4 component tester
short the 3 pins and turn it on - it will go into cal mode
have a 220nF polyester cap handy.
stj is offline   Reply With Quote
Old 02-25-2022, 11:45 AM   #4
Danny75
Default Re: Mtester
Thanks! I will have a look at that pdf
Old 03-01-2022, 03:54 AM   #5
Danny75
Default Re: Mtester
Haven't gone through the calibration section yet but saw the T4 as you described it to be in the pdf. So if I understand it correctly, I have been sold a chinese clone instead of a legit version that I was told it was.
Old 03-01-2022, 05:01 AM   #6
digby1951
City & State: yorkshire
My Country: uk
Line Voltage: england 240v
Default Re: Mtester
yes........i have got the same one..but in kit form
digby1951 is offline   Reply With Quote
Old 03-01-2022, 05:51 AM   #7
Danny75
Default Re: Mtester
Think I overpaid and was fooled by this guy. Sold me some caps back then that were way out of spec too but said they were one of the best available.
The tester was a kit too, had to assemble it and cost me shy of 30 euro's.
Old 03-05-2022, 04:45 PM   #8
volkswagenvan
Volks
City & State: Michigan
My Country: USA
Line Voltage: 120VAC 60Hz.
I'm a: Hobbyist Tech
Default Re: Mtester
These are all some variant of the original creators project.
It has been improved or modified several times by everyone who wished to play with it!
volkswagenvan is offline   Reply With Quote
Old 03-05-2022, 07:02 PM   #9
stj
stj's Avatar
Default Re: Mtester
damn, a T4 is worth about €7
Old 03-05-2022, 07:47 PM   #10
goodpsusearch
City & State: Thessaloniki, Greece
My Country: Greece
Line Voltage: 230VAC 50Hz
Default Re: Mtester
Quote:
Link please?
goodpsusearch is offline   Reply With Quote
Old 03-06-2022, 09:10 AM   #11
stj
stj's Avatar
Default Re: Mtester
ebay or aliexpress.
it's the bottom of the range, the good ones have colour display and some are cased with a lithium battery and zener tester
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
