Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 11-10-2021, 05:42 AM   #1
wkholi
City & State: Cairo Governorate
My Country: Egypt
Default NO PGI signal to ATX power supply.
Hi All:
I have a 1600 watt PSU that does not output PGO. I thought it is a bad chip first, I managed to get an equivalent, But when I started measuring the inputs of the power supervisory chip I found that PGI signal is also zero. could that still be a bad chip? where it shorts the PGI pin?
if not what supplies the chip with PGI signal. where can I get schematics for this power supply? There are so many types of power supplies
The chip is ( 1. HY510N <=> WT7510 <=> ST9S313 <=> PS113 <=>RT7501 ) and i got WT7510 as a substitute.
your help would be appreciated.
Thank you in advance.
The brand of the PSU is SURMA, 90 plus gold.
Note: All voltages on the 24 pin connector are available except PGO and all the cables have 12v and 5v to it.
Photos of PSU are in the attachment.
wkholi is offline   Reply With Quote
Old 11-10-2021, 06:14 AM   #2
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Default Re: NO PGI signal to ATX power supply.
There are no pictures
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is online now   Reply With Quote
Old 11-10-2021, 07:55 AM   #3
wkholi
My Country: Egypt
here are the pictures.
I guess i did not wait till they uploaded .
File Type: jpg 810B415B-A195-4159-9D92-ED57257A52AE.jpg (560.7 KB, 15 views)
File Type: jpg ABECB461-E525-4F9E-A4F1-D2DDEAE18DDD.jpg (624.5 KB, 14 views)
Badcaps.net Technical Forums © 2003 - 2022
