Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 03-10-2022, 02:45 PM   #1
jayjr1105
jayjr1105's Avatar
City & State: Central PA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Finally bit the bullet on the Hakko FR301
I've been eyeing this thing up for years but could never justify the cost. I'm doing more console modding and repairs so I finally bit. I don't have it yet but wondering others opinions. I'll not be surprised to hear "you should have bought X instead". Unlike the hundreds of decent Hakko soldering iron clones, I didn't feel the chinese desoldering clones came anywhere near this unit.
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%
jayjr1105 is offline   Reply With Quote
Old 03-10-2022, 03:29 PM   #2
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Default Re: Finally bit the bullet on the Hakko FR301
It's simply great!
I got one a while ago too, some jobs are just too easy now with it!
Old 03-11-2022, 09:27 AM   #3
jayjr1105
jayjr1105's Avatar
Originally Posted by Per Hansson View Post
It's simply great!
Any tips? Usage or maintenance.
Old 03-11-2022, 11:33 AM   #4
Per Hansson
City & State: ----
My Country: Sweden
It seems pretty simple, you do need to take care of the buildup of crud inside it.
But there are tools included with that, you will notice it because the vacuum becomes much less effective...
Old 03-11-2022, 12:04 PM   #5
jayjr1105
jayjr1105's Avatar
How about tips and filters? I thought about getting one of the larger tips in addition to the 1mm that comes with so I can do bigger ground lugs and such. Does it come with enough filters for a years worth of use or so?
Old 03-11-2022, 01:18 PM   #6
stj
stj's Avatar
City & State: Europe
lol
all these companies kill you on the cost of filters.
make your own with A4 sheet material and a chinese leather punch of the correct diameter.
Old 03-11-2022, 01:46 PM   #7
Per Hansson
City & State: ----
My Country: Sweden
There was a filter or two included I believe, whether that lasts for a year or not would depend allot on usage I'd say
Yea I did get the 4mm x 1mm tip (N61-16) as well, that is very useful for larger contacts.
Old 03-11-2022, 03:14 PM   #8
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Tips and filter are the most two consumables are used on these devices and you should have them on hand also get in the habit of using the tube cleaning rod each time you are about to turn off the unit for the day this is extremely important to do on constantly base’s or you will have to drill open the suction tube if you do not do this every time before you turn it off for the day this has to with the flux in the solder
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 03-11-2022, 08:14 PM   #9
stj
stj's Avatar
one very important thing,
DO NOT ADD FLUX TO THE JOINTS.
the pump will pull it in and it will line and clog the tube and also mess up the filter.
Old 03-11-2022, 08:33 PM   #10
redwire
City & State: Alberta
My Country: Canada
They are susceptible to clogging with solder cooling down in the heating element's tube. You have to use the wire poker, especially with lead-free solders, as a habit.
A few times I've taken out the filter cartridge and poked in reverse, at the vacuum side to push out a broken pin that got pulled in.
If it doesn't work well, your technique needs to change or improve:
Some people hold the vacuum on for too short a time period, leaving some solder in the tube, not long enough to suck it into the filter.
Some people hit the vacuum too soon, before the solder joint is heated up and flowed through to the PC board's other side.
I've seen people wiggle the tip too much and trash the pads. Or not hold the tip flush with the board, so you get a tiny vacuum leak because it's crooked.
If a board has too little factory solder, not enough to really desolder then add solder to the pins first.
For boards with DIP IC's sometimes I put a soldering iron tip on the ICs pins on the top side of the board to melt top layer solder, with the Hakko on the other side of the board I hit the vacuum. When you need a lot of heat for the power pins.
redwire is offline   Reply With Quote
Old 03-12-2022, 12:23 AM   #11
sam_sam_sam
These are very good tips about how to avoid clogging up the tip
Old 03-12-2022, 10:26 AM   #12
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
I've got one of the FR-301 desoldering guns for quite a few years now. Still works like a champ and besides changing a filter here and there everything original. Very good product.
Old 03-12-2022, 12:54 PM   #13
stj
stj's Avatar
as the owner of a pump-in-base type,
a couple of questions i'v wondered for a while.
1: is it heavy?
2: does it vibrate in your hand to a degree that would be an issue with prolonged use?
Old 03-12-2022, 04:09 PM   #14
jayjr1105
jayjr1105's Avatar
1: is it heavy?
1. surprisingly no
2. not really
Old 03-12-2022, 10:06 PM   #15
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
TBH I'd rather pull the trigger than bite the bullet.
Sorry had to make this comment...
eccerr0r is offline   Reply With Quote
Old 03-23-2022, 09:12 PM   #16
clearchris
clearchris's Avatar
City & State: San Antonio
Line Voltage: 120v 60hz / 240v 60hz
I have a chinese one, and I love it. Takes some time to heat up, but once it hits temp it works well. Sometimes you need to add a bit of pb solder to the joint, but when you pull the trigger and hear the slurp... nothing better than that.
clearchris is offline   Reply With Quote
Old 03-23-2022, 09:21 PM   #17
redwire
My Country: Canada
I think the long hose/base desoldering stations make up for the pressure drop with the larger vac pump and extra vacuum solenoid valve for crisp suction.
My Hakko 470 is amazing for heat, it's rated 50W but I use it for soldering too lol.
Really makes the T12 and 888 look bad, now that I know what good heat is like.
My fav is the tip with 1mm hole, fits most caps.
Old 03-23-2022, 09:42 PM   #18
clearchris
clearchris's Avatar
Yeah, it has been years since I opened up my desoldering gun base, but the pump is about fist sized. It's not small, and I have no lack of suction. The base is a bit oversized for what's in there, but I'm pretty sure the same housing fits a desolder gun / soldering iron combo station also.
