Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 02-26-2021, 04:23 AM   #1
WhiteWolfHellas
City & State: Athens
My Country: Greece
I'm a: Knowledge Seeker
Default Samsung UE65F9000SLXXH
Hello, I have this TV for repair and the symptom is that every black background has a red colour like noise. It is not visible in the menu though. I have removed and cleaned all the flex / cable connected on the boards, nothing changed. Is that main board issue?
WhiteWolfHellas is offline   Reply With Quote
Old 02-26-2021, 05:42 AM   #2
Diah
City & State: SA
My Country: Germany
I'm a: Professional Tech
Default Re: Samsung UE65F9000SLXXH
log in service menu from STB state and from there do initial (hard reset ). after you check the white balance all channel value.. write it down over here or upload screen shoot.
Diah is offline   Reply With Quote
Old 02-27-2021, 02:10 AM   #3
WhiteWolfHellas
My Country: Greece
Quote:
Originally Posted by diah View Post
log in service menu from stb state and from there do initial (hard reset ). After you check the white balance all channel value.. Write it down over here or upload screen shoot.
Old 02-27-2021, 04:43 AM   #4
Diah
City & State: SA
My Country: Germany
if you did hard reset from service menu and there no change.... for me its One connect problem
Old 02-28-2021, 06:13 AM   #5
WhiteWolfHellas
My Country: Greece
Quote:
I did factory reset the TV and took a photo.
How can this be a One Connect problem though? The red background is pressent even with One Connect disconnected.
Old 02-28-2021, 06:26 AM   #6
Diah
City & State: SA
My Country: Germany
where are the photo its show this back ground with warning screen about connect the one connect ??????
Old 03-02-2021, 01:37 AM   #7
WhiteWolfHellas
My Country: Greece
You mean this?
Old 03-02-2021, 02:17 AM   #8
Diah
City & State: SA
My Country: Germany
now its clear..yours mainboards integrated with T-CON ..?!!?
Old 03-02-2021, 03:34 AM   #9
WhiteWolfHellas
My Country: Greece
No, the T-Con is separate from the main board.
Old 03-02-2021, 04:00 AM   #10
Diah
City & State: SA
My Country: Germany
in this case you need first to test panel reaction after you connect the one connect and feed video or other ports signal then disconnect one ribbon at time between T-CON and panel. to check if there are any different with it.
Old 03-02-2021, 04:06 AM   #11
WhiteWolfHellas
My Country: Greece
Using the antenna signal (aerial) the screen turns black when I disconnect either of the T-Con flexes to panel.
Old 03-02-2021, 04:48 AM   #12
Diah
City & State: SA
My Country: Germany
remove the metal shield of the 2 boards the back one and the one at the middle. upload focused high resolution photos on both. we need to track the video signal R/G/B-Offset
Old 03-02-2021, 06:15 AM   #13
WhiteWolfHellas
My Country: Greece
remove the metal shield of the 2 boards the back one and the one at the middle. Upload focused high resolution photos on both. We need to track the video signal r/g/b-offset
IMG_20210302_140416[1].jpg T-Con board
IMG_20210302_140408[1].jpg 3-D board(?)
Old 03-02-2021, 06:57 AM   #14
Diah
City & State: SA
My Country: Germany
its difficult to trace the signal walking thru. need to take a look on the other boards with black cover.
BTW: did the "one connect" socket connected to video processing boards ( the middle one ) via the Yellow socket clip?
Old 03-03-2021, 02:18 AM   #15
WhiteWolfHellas
My Country: Greece
The One Connect socket is connected in the main board. The yellow socket connects the main board with the 3-D board if that's what you are asking.
Old 03-03-2021, 02:58 AM   #16
Diah
City & State: SA
My Country: Germany
try first to clean and reseat the black LVDS cable from both sides.. then you have 3 gate IC on the manibiards close to this black LVDS. IC110-111-112 try to freeze or to heat to check any different at screen
Old 03-05-2021, 02:59 AM   #17
WhiteWolfHellas
My Country: Greece
Did everything you said, nothing changed. Could it be a defective panel?
Old 03-05-2021, 06:12 AM   #18
Diah
City & State: SA
My Country: Germany
No,
if you did freeze or heating ICs 110-111-112 with no change.. then you have 90% BGA at the big chip.. look on the left side of the Ics where the print line goes.. at this side of the chip need flux and refellow
Old 03-05-2021, 10:25 AM   #19
WhiteWolfHellas
My Country: Greece
No,
OK, I will do a reflow and report back, thank you for the info brother.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
