Can you dignose from the photo ? . Toshiba 65S2650EV
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    I made a mistake watching the pins because under side photo is mirrored, so the test become so:
    Test in volt on the IC3 pin12 with psu alone.. try also to jumper PS with to gnd and test again IC3 pin12
    the red glue doesn't matter..
      I am just curious about that red .. paint ?
      I can check Pin 12 V with PSU alone, in standby of course. This means the IC gets VCC ( maybe not proper V
      than you suggest I short PS pin to GND ? directly or with 1kOhm ? and check #12 again . Like, sounds a bit strange to short PS Pin to GND . Is this is like the ON signal ? because as I understand, if PS is PSU-On line it should get Voltage, not GND
        Red thing is glue as i said. Since PS is not gnd with PSU alone then is pull-up-ed by a resistor to 5v somewhere, so no need for resistor..
          In both states , #Pin12 ( vs #Pin10 ) I measure ~20mV .
          PS Line was shorted with GND Line
            in both states you mean with/without jumper on PS pin?
            So you know now why the main smps doesn't turn on, both main smps and pfc ic are not fed, now i want you to force its feeding, watch the poor picture below.. i've marked UF1 the turn on command optocoupler, first try to short it's primary side pins, this puts the Q10 base to low (it's probably a PNP) and making primary vcc rail goes to the said 2 ic, then check outputs, if there aren't, check tension on pin 1 of q10, it must be something around 12v-16v, now you can also short pin 1-2 (collector-emitter), check pin12 of ic3 again and check outputs..(12v-led-out)
              "in both states you mean with/without jumper on PS pin?" - Yes. of course.
              Just a quick note :
              I do have ~290V on Main Caps so I think PFC is powered ? and I do have 5.2V on 5VSB.
              And ~2V on PS... this is suspicious as I did see previously 1.35V , maybe because Main is not connected.
              Backlight LED output is 24V . Mainboard gets 12V. different connectors.
              * From what you say , it is obvious that you focus in the Q10 transistor : I will take it out and test it.
                i was happier if you did what i had suggested, the pfc is on when you get about 400v on big caps
                  OK
                  I want to write what I understand the steps are :
                  1. Connect Opto.HotSide Pins
                  2. Check Pin12 on IC3
                  3. No VCC ? -> Check Q10 Pin1 ( as you marked ) : If 12-16V ? -> Connect Pin1 and Pin2 ( As you marked ) on Q10
                  4. Do 2. again and Check if Outputs exist ( 12V, 24V)
                  The only thing unclear is " making primary vcc rail goes to the said 2 ic, " , because the smaller IC is IC2 . I assume you mean VCC Rail goes to Pin12 of IC3
                    steps are ok, the last question i was meaning that the auxiliary of the standby transformer can provide vcc power to pfc ic and main smps ic (ic2, ic3)
                      All bad
                      with Pins 1,2 connected , I get fluctuating ~0.6-2.5 on Pin12 and fluctuating to 1.5 on Q10. High V do not exists , 5VSB and PS are as before but a bit lower and not stable.
                      I verified continuity after jumpering, and separation to pin #3.
                      Uff .. TV from Hell
                      Can I use another PSU to provide 12V and 24V ? might be different GND .. I think I can find a TV PSU board than does provide those and jumpstart it with this PSU.
                        I guess there is a problem in the standby stage, the output doesn't support the load, changing PSU is not an option as you said, you could lost time in tests, you have only to correct the feedback items, then locate and change the TL431 chip under the heat sink, is type To92 package, near the border of board, if it isn't enough change optocoupler U1
                          All this is on the boundary of my understanding, since I know very roughly how a PSU works.
                          I assume by "feedback" ( you have only to correct the feedback items ) you mean the Opto which, being triggered by the PSU-On signal opens Q10 transistor to power IC3.
                          I see 3 AZ431 Transistors near the heatsink on the Cold Side. But TL431 ?
                          Is it a Standby PSU issue or signal issue ? because if the Standby PSU isn't working properly than perhaps the area near the small , yellow , coil should be investigated ?
                          I forgot to upload Q10 photo, so here it is : A684
                            These are the two that must be changed, AZ431 is the same as TL431, them are IC:
                              You mean "replace" , yes ? put new of the same
                              I can test & compare 2 of the AZ431 . How about testing the Mosfets under the big heatsink on the cold side ?
                                you can compare but it's a bit time consuming, replace them and stop
                                  found : ( each line one board )
                                  AS431 , PC123
                                  431A , NEC 2561A
                                  AZ431 , EL 817
                                  TL431 & KA 431AZ , PC817 & cosmo 1010 PC817
                                  our board :
                                  AZ431 , 817c
                                    i don't understand this message.. i have said to you which one to change..
                                    i have forgot one reply, for change i mean replace..
                                      I have 4 bad PSU boards , and I list what they have.
                                      I assume any 431 and any 817C will be good replacement ?
                                        yes, pc123 and 817 the same
                                          OK :
                                          Replaced with AS431 , PC123 .
                                          Tested in TV : same as before - Red LED does not go dark . No BL nothing.
                                          BUT
                                          Measured PSU alone :
                                          1. IC3 Pin12 = 9.8V !
                                          2. Q10 : #1 = 13.57 ; #2 = 13.25 ; #3 = 12.6 . ( #Pin as you wrote ).
                                          3. Opto.ColdSide = 1.12V
                                          So you were again correct : replacing on Cold Side made a big change.
                                          Isn't Pin12, Vcc, too much ? Specs say it can take up to 20V
