Very interesting module XL4015 5A DC Buck Step-down Adjustable Voltage Power Converte
    This is the voltage buck converter in battery testing machine that I use to test batteries with
    This is the part of the modification that I going to do for charging batteries with BMS protection boards I have mentioned this in another post before
    This is why I created a new post for this modification project
    https://www.ebay.com/itm/25479903121...53.m2749.l2649
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Very interesting module XL4015 5A DC Buck Step-down Adjustable Voltage Power Conv
    I have not forgot about this project either but was having a hard time finding a switching power supply that the switching power board profile was the same for a 12 volt switching power supply which I found some and they finally came in the a few days ago from China and when I have some time to work on it
    Here is the 12 volt switching power supply that I am taking about
    https://www.ebay.com/itm/12259701329...53.m2749.l2649
    Here is the 24 volt switching power supply that is used in the battery testing machine
    You have to select 24 volts @ 6 to 9 amp version
    https://www.ebay.com/itm/38371733973...Cclp%3A2047675
    This switching power supply has the same board profile but does not have the same current output
    https://www.ebay.com/itm/12377499516...Cclp%3A2047675
    They all seem to have the same design profile and the same connector profile which hooking up this switching power is going to be easy to do with the hardware and I not going to have to drill any new holes to mount them
    9 PC LCD Monitor
    1 Dell Mother Board
      Well I have finally found a working solution for charging battery packs with BMS protection boards
      Okay this one the current control does not work correctly but the meter module is very accurate for the type of meter it is
      https://www.ebay.com/itm/224143044400
      This one the voltage/current controller works correctly but does not have the meter module but the board layout is the exact same thing so the meter module sit right on top of it but you have to remove the pots from the board that does not work correctly and mount them on this board and you are ready to rock and roll
      https://www.ebay.com/itm/14473812508...Bk9SR5SUk7jyYA
      9 PC LCD Monitor
      1 Dell Mother Board
        Here is the circuit diagram for this version of the voltage/current buck converter that actually works correctly
        https://circuitdigest.com/electronic...nverter-module
        9 PC LCD Monitor
        1 Dell Mother Board
          Update it turns out that only one out of the 5 that I bought was defective and the rest of work correctly
          9 PC LCD Monitor
          1 Dell Mother Board
