hp elitebook 850 g5 bios password
    Re: HP Elitebook 850 G5 Bios Password removal
    works perfect,
    thanks
      Re: hp elitebook 850 g5 bios password
      Hello, I have an HP Elitebook 850 G5 with a bios password
      I wrote the two memoirs I wrote the two memoirs with the dumps posted
      but I have many errors
      Sistem is booting in manufacturing program mode and the laptop starts up very hard
      I also solved errors with the HP MANUFACTURE PROGRAMMING MPM application
      there are two left SISTEM BOARD 00A FEATURE BITE and FACTORY HOST BASED MAC ADRESS
      I also post the 2 original saved dumps
        File & instructions sent.
        Test & leave feedback.
        Become a Badcaps supporter
        Thanks to all supporters.​
          Hello !!
          I wrote the two memoirs and everything works fine !!!
          Thank you very much for your help
            Hello !!
            Good for you. You did a good job too.
            Bravissimo
              I also have the same errors as Babanu after reprogramming the bios.
              Any chance you could send me the instructions to fix it please.
              Do you need my Bios dump?
                hi, kindly can you help me, bios elitebook 850 g5 locked with password.
                thank you
                  thank you
                  use RCUnlocker on the 16MB chip
                    Thank you for your reply and for your interest, before proceeding as you indicated, I forgot to mention that the password is in the Power-On Authentication, so the procedure you gave me, is it okay to unlock? or is there other procedure?
                    Thanks again
                      Thanks again
                      post the 16MB bios here..
                        Hello! I would like to request the HP 850 G5 password to be deleted. I used RcUnlocker, but I couldn't remove the password (what could I have done wrong?) Thank you for your help!
                          Thank you
                            try..
                              Thank you
                              try..
                                Hi All,
                                I have an Elitebook 850 G5 with Bios lock.
                                Tried 128mb dump with RCUnlocker, unlock - ok but after that NB does not start - FAN spin and no picture.
                                I can confirm that the unlock algorithm works fine,NVRAM is deleted(compared to new and unlocked dump).
                                Anyone have experience with this model?Maybe I need to modify the 256mb flash?
                                By comparing 840 G5 main dumps(locked/unlocked) I can see some difference in User Area(there "A.d.m.i.n.P.W...)...
                                Please help.
                                  try..
                                  Thanks! I will try it soon
                                    try..
                                    Thanks for the help, but unfortunately it doesn't work, the computer starts like a backup of the bios and then says "Security Device Problem" I click on "OK" and it takes me back to the "Power-On Authentication" screen where it asks me to put the password.
                                    Maybe it's my fault, because the dump I uploaded was not good, as I compared it with the other dumps and it was not the same, so I submit a new dump which I am sure is good as I did 3 new readings and they are all 3 identical.
                                    P.S. I use a CH341A because EZP2019 + does not recognize me the 25q128jv.
                                    What software version do you recommend for the CH341A?
                                    Thank you
                                      Thank you
                                      try these two tools..
                                      https://www.badcaps.net/forum/showpo...6&postcount=10
                                      https://www.badcaps.net/forum/showpo...04&postcount=7
                                        plz bios password for hp 840-G5
                                          the password is in the 16MB chip...use RCUnlocker and unlock it yourself..be careful not to delete the original bios..
