Sony VGN-AW | MBX-194 | No Backlight
    I got post screen, without backlight.
    I am searching for classic sony vaio "Z" or "F" fuse near lcd cable connector but i can find something familiar.
    Can anyone help me locate the fuse ?
    Re: Sony VGN-AW | MBX-194 | No Backlight
    voltage in pin 28 29 30 CN6 connector
    This model has the inverter you have to check it
      Thanks for the reply.
      The screen model is LTN184HT02.
      Where is the inverter at that screen located - might you know ?
        what is you mother baord model exact the image doen't match the Screen you are having a LCD screen not LED ?
          The screen at the picture is 100% the same is the laptop's.
          There is no inverter somewhere.
          There are photos of the motherboard:
            your Schematic page 32 LVDS section in the Motherboad not the screen voltage in pin 28 29 30 CN6 connector
              On this series the panel has ccfl for backlight.
              I would start with checking the inverter board (small board located on bottom of the screen).
              If you don't have another inverter for check try with another ccfl panel or do some measurements on the input of the inverter board.
                What revision number is the screen. Check post 95 http://forum.notebookreview.com/thre...654639/page-10
                  I dont think that its a CCFL Screen, there is no inverter.
                    The full screen model is LTN184HT02-S01, so its a LED screen, thats why i am searching for the classic "f" or "z" fuse with vaio led laptops has near screen connector and its responsible for backlight.
                      You have a revision 2.0 motherboard. My guess is the rev 2.0 motherboard came with LED screens and the earlier rev motherboards came with LCD`s. There is no schematic available for the rev 2.0 . Can you take a close up picture of the LVDS connector area ,and give us voltage measurements for all the pins .
                        Thats the reason...
                        Okay, i will perform tests and let you know.
                          Thats the reason...
                          I gave up and forward the board to a colleague of mine.
