List of pin compatible Laptop ICs
This is a sticky topic.
    Re: List of pin compatible Laptop ICs
    can i replace RT8205B with RT8205C?
      with the changes from pin 18 and 19 I think it works..
      TPS51125= RT8205B
        Tested 100% working SYX196BQNC=SY8206BQNC
          thank you it worked with dell 3521
            I have what I believe is an NCP511SN25T1G, which is a 2.5V output LDO in a SOT-23-5 package - is this interchangeable with either an ADP151AUJZ-2.5-R7 or a TLV70025DDCT by any chance?
            Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
              Just a follow up, I fitted the ADP151 today and it seems to be working absolutely fine.
                4957agm Any compatible mosfet?
                  Does any one know compatible for BQ738H ?
                  I have BQ738. are they same?
                    Originally posted by kadi144 View Post
                    can i use a TPS51216 or BQ 727 as replacement of TPS 51716 in DELL INSPIR0N 15-3000
                    i don't think so, whilst they're pin-compatible, the mode pin takes completely different resistors (i'm having this exact same issue), since 51716 can control up to DDR4 and has much higher switching freq. (500 to 670Khz) whilst 216 goes to 400Khz
                      Good day does anybody know what ic represents 5x=5j s8n labeled on top? tried searching net, empty handed. Dont have schematic for this hp slimline. Thanks.
                        Ok I got it now sorry for lazy researching its a RT6575D. Thanks
                          Guys any other compatible with this ic?
                            Originally posted by highpulse View Post
                            51123 can be replaced by 51125
                            No
                              max17020=isl6236
                                I have a Lenovo Flex 2 (14D) with a burnt NPCE285GA0DX EC chip and I have a spare NPCE285PA0DX. Are these chips compatible?
                                  CD3301BRHHR_QFN36 dell Latitude E7440 charger ic replacement ????
                                    What is compatible with APW88688 / APW 88688 ?
                                      Any compatible for AMD 216-0752001,
                                        Is MEC1300-NU compatible with MEC-1310-NU? I can't find the datasheet or the pinout of either.
                                          can someone confirm is G5244T11U and SY6288C20AAC interchangable?
