MSI 401X No DISPLAY
    MSI 401X No DISPLAY
    hello there
    i have repair
    Model MSI 401X
    MOBO : MS14331 rev. 1.0
    no display on LED Screen but Have Display on External VGA
    i already replace both new 100% working LED And LED Flex Change
    I request Schematic Diagram..
    Help PLs...
    TIA
    Re: MSI 401X No DISPLAY
    Follow Up
      Up
      Up
      Up
      Please....
        probably bad solder joints on vga chip due clogged fan
          what do you mean my friend. need to Re heat the VGA Chip (GPU Chip) ?
            Have you checked if backlight is enabled? if so, try these:
            Try to press the VGA chip while powering on and observe if current consumption increased or led screen will have display.
            You may also try to reflow (as a temporary fix) to confirm that vga chip needs a reball or replacement.
              thanks for this Idea Master...
