Blown component identification - EVGA 1000 GQ
    Any idea what the green component is / value?
    Mine is completely blown and unidentifiable. Green disk risister
    I found some pics online that show it, either a varistor or thermistor i think.
    Next to the bridge rectifiers
    Some pics attached
    and more on jonnyyguru
    https://www.jonnyguru.com/blog/2015/...ower-supply/5/
    Re: Blown component identification - EVGA 1000 GQ
    Yes it is a NTC thermistor to limit inrush current when the capacitors charge up from being off for some time.
    It is then bypassed by the relay next to it to increase efficiency.
    The value is not so important, it only needs to be large enough to survive the brief inrush.
    So anything from a similar rated power supply should be fine.
      Any roughy values you could suggest, as would need to order one online and not sure what to get.
      Something like this
      https://www.ebay.com/itm/SCK-056-NTC...-/323908232878
        It may have blown due to relay contacts are bad and not bypassing it, or you may have shorts circuit, you need to check other component as well.
          The internal fuse is not blown if that is of usefulness.
          Now that the part is identified I’ll check for shorts on bridge rectifiers and around that area.
            https://www.rapidonline.com/NTC-Inrush-Limiters
            Some here as well
            Do I need low ohm or higher ohm versions?
              You can try once without it: the same will happen if the PSU is switched off and on quite fast:
              Then the NTC will not have time to cool down so it will be low resistance and thus the caps charge up violently instead.
              As budm said you should check other things, best to do this test with an incandescent light bulb, you can attach that in place of the NTC. (much better than a straight wire bypass)
