Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 09-19-2015, 06:20 AM   #61
scokljat
scokljat's Avatar
City & State: Zagreb
My Country: Croatia
Line Voltage: 230VAC 50Hz
I'm a: Knowledge Seeker
Default Re: Samsung PS-42D4S plasma. Has sound, no picture. Please help! - FIXED!
FIXED!!! :-) After replacing ML 4824 I got normal Vs and other missing voltages. TV works great, picture is fine! I really love this TV.
So, it was ML4824 after all - my first suspect! Actually, if they had IP version of IC in the local shop, I would replace it 4 weeks ago even before posting here. I'm little bit worried because I used CP version of IC as it has lower temperature range than IP, but I hope it will work for next few years...
I got following voltages:
Vs = 176V
Ve = 166,2V
Vset = 165,5V
Va = 70,1V
Vsc = -70.1V
Thank you for your help!
Cheers!
S
PS. now when I'm thinking of possible causes for this faliure, I must say I started to watch some lame Bruce Willis SF movie the night before TV died. Movie is so lame that I quit watching 15 minutes after beginning and go to sleep. Next day TV was dead. So, it must be this stupid movie! Ha?
scokljat is offline   Reply With Quote
Old 09-19-2015, 09:10 AM   #62
Maklaud
City & State: Yekaterinburg
My Country: Russia
Line Voltage: 220VAC 50Hz
Thumbs up Re: Samsung PS-42D4S plasma. Has sound, no picture. Please help!
Awesome!
Maklaud is offline   Reply With Quote
Old 09-19-2015, 09:44 AM   #63
ReeceyBurger123
Never Give Up !
ReeceyBurger123's Avatar
City & State: Telford
My Country: Britain
Line Voltage: 240 VAC 50Hz
I'm a: Student Tech
Ww fair play !! Very welldone to you
ReeceyBurger123 is offline   Reply With Quote
Old 03-24-2016, 06:14 AM   #64
protektwar
City & State: Heiligenhaus
My Country: Germany
I followed the post thread until the end and based on this thread I replaced the ML4824 IC1 and IR2109 IC30, but still no luck.
Below you can see the reading from my TV:
VA = 70V OK
Vscan = -70V OK
VS = 8,57V Wrong (175V written on board)
VE = 4,49V Wrong (165V written on board)
Vset = 3,66V Wrong (165V written on board)
VG = 15V OK
VT = 33V OK
A6V = 6.11V OK
A12V = 12.94V OK
D3.3V = 3.25V OK
D5V = 5.18V OK
D6V = 6.16V OK
D12V = 12.94V OK
STD5V = 5.1V OK
B+_PFC = 400V measured between Q8S and Q6D
Stand-by VS_ON = 0.4V OK
ON VS_ON = 0.09V Wrong
Stand-by PS_ON = 3.3V OK
ON PS_ON = 0.25V OK
ML4824 when ON
PIN 1 = 3,67V | PIN 16 = 1,9V
PIN 2 = 1,27V | PIN 15 = 2,5V
PIN 3 = 0V | PIN 14 = 7,56V
PIN 4 = 3,62V | PIN 13 = 13,46V
PIN 5 = 0V | PIN 12 = 0.9V
PIN 6 = 7.56V | PIN 11 = 0.2V
PIN 7 = 2,62V | PIN 10 = GND
PIN 8 = 2V | PIN 9 =
Based on Power Supply schematics VS_ON is coming from another board under the the main board(where the plugs are located), named LOGIC board, as you can see in the attached file(Exploded View & Part List.pdf).
Can someone help me?
protektwar is offline   Reply With Quote
Old 05-12-2016, 05:18 PM   #65
scokljat
scokljat's Avatar
My Country: Croatia
Did you manage to repair it?
Regards,
Suad
Old 04-04-2019, 09:39 PM   #66
nickBcap
City & State: Auckland
My Country: New Zealand
Line Voltage: 240V 60Hz I think ??
I'm a: Professional Tech
Hi, will I be of any help here....? I was brought this TV board because I could solder and de solder and there was bulging capacitors on the power board. Exactly the same model, Samsung Board; BN96-01217A Model Name:V3V Rev: 1.1.
So after browsing through this thread and downloading all info pics etc, trying to find out where I should place the new capacitors I thought perhaps smarter electronics repairs guys could perhaps figure out other problems concerning this TV board by showing you which capacitors I removed from the board and showing you the replacement capacitors I bought.
This began 8 years ago and I am now not sure where each of the three different (4 in total) capacitors should be soldered onto the board.
Pictures Attached
EDITED: also hoping someone can tell where to solder the capacitor replacements I bout about 6 years ago (lol) so maybe I can sell a repaired power and working power board. I will be trying to work out the correct positions on the board for the capacitors I bought.
I do not do much of this kind of repair work I am more a computer repair guy, but I am still learning little by little electronics repairs.
Thank you
nickBcap is offline   Reply With Quote
Old 04-12-2019, 08:43 PM   #67
nickBcap
I am ok with the two larger capacitors, it is the two smaller capacitor placement positions I need help with.
Old 04-12-2019, 09:57 PM   #68
R_J
City & State: ☻
My Country: Canada
C310 = 1500f/10v
C314 = 1500f/10v
C104 = 100f/35v
C33 = 1/50v
R_J is offline   Reply With Quote
Old 04-17-2019, 12:13 AM   #69
nickBcap
Smile Re: Samsung PS-42D4S plasma. Has sound, no picture. Please help!
Thank you
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
