Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 06-15-2020, 09:41 PM   #1
nickBcap
City & State: Auckland
My Country: New Zealand
Line Voltage: 240V 60Hz I think ??
Default Hakko FX-888D toroidal transformer upgrade to 240V
I was using a Singway 120-240V < > voltage convertor from Ebay but it was not good enough, it popped and the fuse in the Hakko blew also.
I have been looking at replacing the Hakko 110V transformer (I can trade the transformer if anyone needs it) with a toroidal transformer.
I have looked at projects and they seem to have been successful but also seem to have used single Voltage Out toroidal transformers. But, the only toroidal transformers I found all have dual 12V or dual 24V Voltage Out.
It seems I should have to use a single Voltage Out toroidal transformer and not a Dual Voltage Out toroidal transformer.
May I have some advice please.
nickBcap is offline   Reply With Quote
Old 06-16-2020, 04:14 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Hakko FX-888D toroidal transformer upgrade to 240V
you connect the 12v windings in series.
Old 06-16-2020, 04:23 AM   #3
nickBcap
Ok great!
Thank you
Old 06-18-2020, 05:56 PM   #4
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Please note that Toroid transformer has high in rush current thane E-core transformer so it may pop the fuse that you have right now.
http://engineering.nyu.edu/power/sit.../Reduction.pdf
https://www.ametherm.com/blog/inrush...s-got-you-down
Old 06-20-2020, 07:57 AM   #5
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Thanks for this information ( I Did not know this about Toroid transformers )
I have only seen this type of transformer a few times in a few devices I have seen them at some electronic surplus supply stores online I have been tempted a few times in the past to buy some but not have any experience using them I have not bought any of them
I will read about this type of transformers from the website links that you provide
Thanks again for information
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
