Symptoms: No display, no backlight, front display light blinks off once every 15 seconds
other: Unit powers on indicated by light under "Sharp" name
I purchased this TV hoping to repair it. My troubleshooting skills might seem a little primitive.....actually they are primitive but I am trying. This is what I have noticed. The remote power button and the side panel on/off switch do not toggle the power without disconnecting the cables mentioned below. If I disconnect the left side ribbon cable between the T-CON board and the panel the left half of the display and the backlights will come on and display a half perfect menu. Disconnecting the left side cable also allows the power to be cycled with either the remote control or the side panel on\off switch. When the right side T-CON ribbon cable(T-CON to panel) is removed the backlights and image remain off. Disconnecting the 4-wire cable(12v PS to T-CON)or the ribbon cable(Main board to T-CON board) also allows the backlights to come on. I am assuming since my panel is capable of displaying half an image it should be capable of displaying a complete image. I am also guessing the T-CON board has failed but would like some advice from someone familiar with Sharp LCD TV's.
I would also be eternally grateful to anyone who has a service manual for this model TV.
Thank you very much
Thank you very much
