Re: Replacing OST caps on Microstar KT6 Delta motherboard
If those readings are taken with the MOSFETs on the board, you probably have something else affecting them as these don't look very meaningful. But anyways, I guess it is better to grab a few spare MOSFETs than to ponder whether the ones on the board are currently shorted or not.
^Wrong link?
Whatever you linked to does not list 1.1 uH, 25A choke. In fact, the lowest I see for through-hole inductors is 5.6 uH, which is a bit too high. SMD does have 1.1uH, but the current is way too low. However, I did find an SMD inductor rated for 1.2 uH and 25.4A here:
http://nz.element14.com/bourns-jw-mi...-20/dp/1180547
That should work, though, you may have to solder leads to it (preferably very thick ones) to attach it to the board (actually, it would probably be easier to solder the thick leads to the board and then the inductor to them). Kind of ghetto, but should work.
Also, I suggest you count the number of turns of wire on the good inductor and post it here. Should help with finding a proper one easier... or worst case scenario, use that info to pull something from another dead motherboard. Whenever you see inductors on PC hardware that might say something like "aRb", that means a.b uH (where "a" and "b" are single-digit numbers). Similarly, "Rab" translates to 0.ab uH.
Or worst worst case scenario - run the board with just half the VRM phases - i.e. with the broken choke (and associated MOSFETs) removed from the board. But a high power CPU could overload the other working VRM phase... so yeah, best saved as a last resort.
^Yup, that's a Fairchild MOSFET. Part number is FDB6670AL. The MOSFET you linked to is a bit under-specced on the DC continuous current, but it has a higher pulse current, and same Rds(on) resistance, so it should work just fine. However, do note that what you linked to is a TO-263-3 case and not simply a TO-263. That means, the middle pin on the MOSFET is not cut off, so you probably will have to cut it yourself. But that shouldn't be a problem.
Originally posted by socketa
View Post
View Post
View Post
