A7S333 1 long beep 3 short beep and shut down ?
    Re: A7S333 1 long beep 3 short beep and shut down ?
    On POST code diagnostic I got C1 and motherboard is off after that....
    What does it say to me ? any experiences ?
      can it be the audio modem chip is short and making all the system shutdown...?
      It's the closest to LM78L05
      https://cdn.badcaps-static.com/pdfs/...c2f51bc7b4.pdf
        C1
        Detect memory
        -Auto-detection of DRAM size, type and ECC
          but it shut off after showing C1.....how do you reckon ? is it something wrong with my VRM
          ? I've replaced all the FET and Caps...but no avail...could be my buck controller and driver ?
          NCP5322 ?
            LM78L05ACM is connected directly to 74HC4053...which a logic HCMOS chip...
            I have no idea what's it doing yet ??
              74HC4053, could it be died already ? and making the system shut off ??
                  exact chip :
                    Is it possible that I get a corrupted BIOS ?
                      can I upload this one
                      http://dlcdnet.asus.com/pub/ASUS/mb/...316.1472338911
                      straight away with chip flash programmer ? thanks
                        1 long and 3 short beeps is no VGA detected.
                        https://www.asus.com/support/faq/1029959
                        Are you testing with a known quality working PSU ?
                          Yes I'm using a working PSU...I've tested this PSU with other mobo...works ok...
                          I will try changing buck controller and see...
                          either death buck or corrupted BIOS or both...
                            I got progress....I've replaced all the FET and now it bot until displaying C1C1 on POST diagnostic...beep...and shut down...
                            I think it's NCP5322 buck controller not right....
                            Do you reckon ?
                              from physical appearance, looks like NCP5322 buck controller is burned, please have a look at the photo...
                                Are you serious ? You can't see anything in that photo.
                                  Can't you see the chip next to CPU on the right ?....ok, I'll try taking picture again...
                                    Another photo...hope it's better now...
                                      I can't read the label on NCP5322, because of burn I suppose...must take a good closer look with magnifying glass to see its label....
                                        Buck controller seems fine to me.
                                        Why do you always think it's the buck controller that's the problem?
                                        Honestly, from all of the motherboards I got in for repair, I've never had to replace a buck controller. Maybe a few FETs and the occasional FET driver. The buck controller is protected pretty well.
                                          I have replaced all the FETs and it's still happened....turn on trying to POST and shut off after few seconds ?? do you know what else then ?
