P5PE-VM question ?
    Re: P5PE-VM question ?
    CLOCK LED is very dim......there's no CLOCK ??
      The clock generator chip is :
      CLK865J02FLF....I can't find datasheet for it...can you ?
        any clues guys ?
          Is the crystal ok ?
            Yes the crystal is ok, I've check it on the scope....
            Anything else do you reckon ?
              I measured the voltage around CPU it's 1.37V for 3 pairs of FET...are they normal or one of them faulty ?
              The CPU is Celeron D 346 ...
                I reckon it's normal...
                http://ark.intel.com/products/27125/...Hz-533-MHz-FSB
                Can I check the clock of the processor ? which pin is it ?
                I can't find CLK865J02FLF datasheet....must be somewhere there...oo...trouble..
                  I've been looking at:
                  but on PCB...it's not easy to get it....since it's BGA style soldered...and LGA775 socket is too fragile to measure directly....
                    I checked the voltage on positive side of CMOS battery...(without the battery ) ....abit strange....the value is up and down .....??
                      I got 0 - 4 ohm from every FET near the CPU to GND....is that allright or abnormal ?
                        FET ( source pin )
                          3 FETs got 0.000V for diode test for DMM ?? faulty ? D - S test drain to negative probe , S to positive probe...in circuit test..
                            Do you think those tilting capacitors are bad ?
                              I'll check 32KHz crystal as well....may be it's faulty ?
                                It was long beep, short beep, short beep....time when I changed the crystal...but when I shut it off...it's showing 0000 again in POST diagnostic...
                                I tried pushing abit on southbridge chip and it's showing D3D3 on post diagnostic....
                                I guess I got bad join on southbridge...
                                Reflow do you reckon ?
                                  Was it successful ?
                                    only one time working with new crystal, beep beep beep....I recycled the power....
                                    and it returned to 0000 again....
                                    and I can't see 32768 Hz on any pins of the crystal...is my crystal faulty again ?
                                    how can I test a crystal ?
                                    Can I use this one for replacing it ?
                                    http://www.aliexpress.com/item/Free-...999.261.WwQahB
                                      Post #25. The same way you tested that crystal.
                                      I test mine with one of these. http://www.aliexpress.com/item/DIY-K...413364646.html
                                        I checked the voltage of FET near the CPU with scope....on Drain it's 40V and on Source 18V...frequency = 110KHz
                                          Interesting, how can we use it ? where can we put our crystal ?
