Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
    Re: Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
    From My research i have found the transistor for q1314
    it is DTA143XKA or DTA143XUA, depending on package
    i cant find these anywhere
    which ones can i use as a replacement please
    thanks
      If Q1316 is shorted e~c that would explain why the motor is on. I would replace it, Q1314 is likely ok.
      The KA is larger, you need to measure the original to see which will fit the pads.
        Thanks for the reply
        I cant find anywhere that sells these
        Can you post some alternatives or compatibles ones
        Not sure if some values can be changed
        Thanks so much
          Digikey stocks both parts.
            Thanks for the reply.
            Are there any compatible or alternatives that I can buy from ebay or aliexpress
            Digikey I will have buy apps for free shipping
            Thanks so much in advance
              I know I only need one but if I order both at the same time I have them on hand just incase
                Would this be ok to use as an alternative if needed for q1314
                https://cdn.badcaps-static.com/pdfs/...f4c949429a.pdf
                Please let me know, all
                  NO, that is a mosfet. Why do you think it is bad????
                    Thanks.
                    My thinking is that when q1316 shorted it would have taken out Q1314
                    Because the emitter and collector shorted on Q1316
                    If I replace Q1314 and doesn't work it would be handy to have on hand to replace it
                    Could you advise of some suitable compatinle replacements please that is available on ebay or aliexpress. Thanks
                      Go to EBAY, then type DTA143X, There is a ad for 5pcs X DTA143X 340t-23 The picture shows DTA143XKA
                      All you need to do is measure the case on the original to know which part to order. They are electrically the same, just the foot print is slightly different.
                      Q1316 likely shorted do to high current in motor, maybe the mechanism jammed causing the motor to stall and draw excessive current
                        Hi
                        I can't find them
                        Can you recommend some other ones please
                          Hi
                          I can't find them
                          Hi
                          I have sourced some
                          I will order them
                          hopefully they arrived soon
