Panasonic TX-32LZD80 backlight no picture (fixed)
    Just picked this up, very local to me. Fault was originally described as no picture and I was about to diagnose a bad inverter until I saw this TV does have a backlight, it's just incredibly dark because it's an IPS panel (very high contrast ratio, but also lower brightness.) I might try increasing the current control on the inverter board to see if the brightness will go up a bit more.
    Found the t-con fuse to be blown. Replace that and it worked.
    Wish I could make it more glamorous but hard to go wrong with a 32 inch Full HD Panasonic like this, they're very well built. 2008 series. Picture is no where near as good as my PZ80 plasma though! Panel is a Panasonic too; IPS Alpha tech.
  • safesurfer65
    • Feb 2014
    • 112
    • Scotland
    Re: Panasonic TX-32LZD80 backlight no picture (fixed)
    Hi Tom
    I've got a the exact same model of TV as this and it has the exact same problem. Can you tell me where the T-Con fuse you talk about is located ?
    Many thanks
    Mark
      It's right near the LVDS connector, little black thing. No photos of it, sorry. But it is obvious.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        another easy fix, saved from the landfill as well. I wish i could find more sets to repair not much around at the minute.
          This was about 6 months ago and it was fixed for a friend who found it on Gumtree like this
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            yes just saw that now haha but hey its fixed and saved i guess.
              Still going strong though. Only thing I'm not a fan of is the dim image, OK in a dark room like his though.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                no i like nice bright clear images my self to be honest is this how these tx-32lzd80 are designed then?
                  Yep, seen a couple others looking the same so figure it's just how they are made. Have not tried to adjust it yet.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    im sure you will when you get another project to work on.
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      Hi guys where did you purchase the replacement fuse as I have the same set with same problem.
                      Thanks in advance.
                      @safesurfer65 if you still need a pic I can upload one for you.
                        CPC stock them. Is there a rating, e.g. 1.3A 32V(T) printed next to the fuse? Or alternatively, a letter on the fuse?
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          Yes Tom, it's 24v / 1.6A. PN or txt on the comp body is I62 NCC hard to make our as it's so small , 1206 package I think.
                          Thanks for the reply,
                          Stephen
                            I think I ended up using a 1.5A fuse
                            http://cpc.farnell.com/multicomp/mc1...-5a/dp/FF02271
                            Min order with CPC is £5 now so you may have to add some solder wick or other things to the order.
                            • StephenU
                              • Dec 2013
                              • 230
                              • United Kingdom
                              Thanks so much for the quick reply, I'll get this ordered and changed. Can't thank you enough, will post results when complete.
                              • StephenU
                                • Dec 2013
                                • 230
                                • United Kingdom
                                [UPDATE FIXED]
                                Well fuses arrived replaced and all working perfect.
                                T-CON - 19100096 MDK 336V-0
                                Great info thanks.
                                Pics below >>
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  Originally posted by StephenU
                                  [UPDATE FIXED]
                                  Great info thanks.
                                  Pics below >>
                                  its nice when its a cheap fix and it works 100% fine again.
                                  • StephenU
                                    • Dec 2013
                                    • 230
                                    • United Kingdom
                                    It sure is that vinceroger69. Now onto the next!
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      Thats how i started too, fixed one then thought this could make a good hobby so now pick up free ones from freecycle gumtree etc to practice repairs one. I also done a few laptop repairs now once you get the electronics bug its hard to stop although theres a lot to learn good job for sites like this and google also some good youtube videos on repairs/testing tips etc.
                                      • jimisjoint
                                        • Jan 2015
                                        • 1
                                        • United Kingdom
                                        Amazing!!!! I have a degree in Physics but no experience in tv repair at all. Followed your advice and bam, perfectly functioning television. Can't thank you enough. The pictures and website were particularly useful.
                                        I have fixed my first tv and am on cloud 9.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Bazfletch3
                                          Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                          by Bazfletch3
                                          Hi all
                                          While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                          I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                          From there I envisaged that the backlighting wasn't working, however...
                                          01-08-2024, 10:18 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
