Samsung PN58B860 Plasma suddenly shutdown and will not restart
    Re: Samsung PN58B860 Plasma suddenly shutdown and will not restart
    OK, so it seems to me like the problem is with the left hand board. Do you want to try repairing it, or just replace it?
      Definitely want to repair if possible!
        No fun just replacing a board. Haha
          Can you try reading off the BN44-######A number printed on the board. For example BN44-12345A.
            Vd code bn44-00278a
              Hmm, no schematic. Have to do this the hard way. Can you remove the board and get detailed, clear photos of the top (white side) and bottom (green side) of the board. Be careful to allow the capacitors on it to discharge to a safe level (less than 30V DC.)
                How's this?
                The back looks a little blurry, guess I'll try that one again
                  Yeah, I'm going to need a clearer photo, any chance you can take a closer up picture, maybe in multiple photos?
                    Would it help if I purchased the service manual? Would it have the schematics you need?
                      Here are three more pics of the back
                        No need to purchase a manual, at least for now.
                        What is the part # on ICP801S, the multi-leaded chip?
                          9d1y 2a20112
                            Datasheet:
                              Check DP803, DP804 for shorts across pins 1-3 to 2 (note pins 1 and 3 joined on PCB so will show as shorted)
                              With board installed in TV, check voltage on JP830, positive on JP830, negative on a PRIMARY_GND pin. Should be near 14.5V.
                                Sorry, you may have lost me. I don't see pin 3 connected to anything. I'm also not sure where DP803/4 are...
                                  Found the DPs!
                                    Oh, when you mentioned pins I thought you were referencing the IC. I think I've got it now
                                      Both DPs read 0.4 Ohms across 1/3 to 2
                                        1 being top pin, 2 being middle, 3 being bottom, you get a short between 1 and 2, 3 and 2?
                                          Yes
