Yamaha RX-V675, No sound
    I got yamaha rx v675, it have no sound , i already done factory reset but still no change. i checked zone 2 line output ., there i am getting sound ,
    Re: Yamaha RX-V675, No sound
    ANYBODY CAN help me for this
      i am geting sound in pure direct mode only
        Originally posted by srt1 View Post
        i got yamaha rx v675, it have no sound , i already done factory reset but still no change. I checked zone 2 line output ., there i am getting sound ,
        help please
          You tried going though the diagnostic options and see if that picks any thing up ?.
          I would check the front panel for dry joints, would all so check if analog and digital are effected though different rear ports too.
          I cannot really help you but thought i would try at least.
            I tried everything.. i am getting sound only when i am connecting analog signal in pure direct mode.. in any dsp mode no sound coming.. also i tried rest, after that i tried to upgrade firmware but its always failing..
              DSP/DTS IC has failed many times in Onkyo, Harman etc maybe the case here.
                But how i confirm dts chip already failed.if it failed i want replce it
                  Yes that would not surprise me, seems to be a common issue with AV HDMI devices and typically due to heat.
                  In some cases people have heated up the DTS chip to get it working, replacing it will not be any fun at all.
                    DTS chip number is D80YK113CPTP4 . is this ic also premature failing as in onkyo?
                      Hii i replced the dsp chip but still no sound ,when i am updating firmware its failing and showing error code 0010 also i check in daignostic menu its showing dsp bus NG ,same as before..what will be the couse
                        Any one can help me , what i do next?
                          Any follow up on this?
                            Would like to revive this topic.
                            Currently working on my Yamaha RX-V673 which also has infamous D80YK113CPTP4 DSP IC. When PCBA is bent or small portion of heat applied (e.g. hot air) to the IC, DSP is OK (viewing via Service Mode, C category, DSP1 BUS: OK/NG) and NG when cooled.
                            Has anyone tried replacing to a new D revision chip from aliexpress? Not quite sure whether DSP IC is bad itself or cracks in tracks/vias.
                              I had a problem when loading firmware had error 0010, heated the chip firmware installed OK but when chip cooled no sound.
                              I was thinking of changing DSP IC don't know if it has to be pre programmed.
