Desoldering Iron upgrade
    Hello everyone
    I would like to upgrade to a desoldering station. At the moment I am using
    Radio shack bulb sucker which is fine except that tips ware out fast.
    For an occasional monitor repair I am interested in this model
    http://www.circuitspecialists.com/csi474a.html has anyone bought this and
    do you like it. the price is much better then any other product and shipping is much cheaper then ordering from China
    Thank you
    Re: De-soldering Iron upgrade
    I could be wrong about this.....but
    The gun look like the desoldering station I have and its made in China
    But they have discontinued the model that I have and they have a new model
    some of the part look the same the tips the spring the suction can and filter
    I have some issue with setup
    One is the heater elements they do not last very long in running hours
    Two is the tips do not last long in respect of how many part that you can remove.........>
    .....>one note the manual says you should not touch the board with the tip.....> doing this dose not work very well
    Three the filter do not last long ether
    Four the filter spring need to be clean with a soldering iron do not be temped
    to clean this spring by pulling the spring to clean out the old solder from it
    But other than these item it a good tool to have for the money but you will have to spend on spare parts to keep it working
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Re: Desoldering Iron upgrade
      Originally posted by 1supertech View Post
      Hello everyone
      Here is what I did.....> if you do not want spend lot of money I use this set up at work it works very well
      Buy one.....> 60W Soldering Iron Model: TR-60 | Catalog #: 64-216 Radio Shack ( Do not use this iron with out a dimmer switch it get very HOT with the dimmer switch it has very usable range even if the dimmer switch is turn all the way ON )
      Buy one.....> 45-Watt De-soldering Iron Model: 64-2060 | Catalog #: 64-2060 Radio Shack (this iron dose not get hot enough with the dimmer switch and with out the dimmer switch you can not control the amount of heat you are put on a board )
      Buy one light dimer switch
      Take the De-soldering part off the heater part there are two set screw loosen the [it is larger and longer than the other one DO NOT loosen the other set screw ] the same set screw setup is on the 60 watt iron
      Take the tip out of the 60 watt iron and put De-soldering in it place an take the dimmer switch to control the iron and like I said before it works very well for the money about $40.00 you will spend on this set up
      De-soldering Bulb Model: 64-2086 | Catalog #: 64-2086 Radio Shack is the bulb that is use on the De-soldering part of the iron
      I hope this helps
      9 PC LCD Monitor
      1 Dell Mother Board
        Well I decided to buy the blackjackack bk 4000 circuitspecialists.com
        Can't be worse then radioshack tips ware fast and clogs up ones in a while.
        I only repair maybe 10 monitors a month. thanks for the info Sam
          I have made several purchases from circuit specialist website. here is what I purchase:
          Soldering station BK2000+
          BK4050 Hot Air Station with Vacuum component handler & Mechanical Arm
          The soldering station work great for about 6 months or more, then I will have to replace a component inside I believe its a triac the that drive the soldering heating element. I get a fluctuation in the soldering iron temp when the triac start to fail. But this is minor issue because I use this station a lot. Overall its work great.
          work great its heat up very fast and the temp hold very steady. the Mechanical Arm come in very handy. no problem so far had it about 6 months plus now.
          give an update on your purchase
          Hope this help
          ecking767
            BLACKJACK SOLDERWERKS DESOLDER
            ING STATION FOR THRU-HOLE COMPONENTS review
            I just received my Blackjack desoldering station
            Tool was packed well and looks great desolders caps with ease a lot faster then radio shack pumps. The only problem I have is desoldering small caps on main board it will not suck up the solder 400deg F even after adding solder to cap. If main boards are double layer pcbs solder station does not desolders small caps, unless I need a finer tip any suggestions welcome
              Playing around some more I raised the temp to between 600 & 800 deg F sometimes it helped but some joints where not easy to desolder. It's is not as immediate as desoldering power supply board.
                Ok I am now trying to desolders caps off a junk motherboard, it seems that it is easier to desolder motherboard caps then a main board cap , but the positive side of cap is harder to desolders then the negative side on motherboards
                The iron does not burn the pcb as it states on the directions. I am getting used to this tool
                Overall impression for 150.00 with shipping its better then radio shack desolders pump
                But not good enough for a busy repair shop
                  motherboard is a multi layer PCB = lots of copper benith.
                  It worths to try to preheat it with a simple hair dryer for 1-3 minutes before attaching the soldering iron to it.
                    Thanks Kiriakos GR I will try that
                      I used my hot air gun to heat up main board caps came off very easy
                      thanks Kiriakos
                        You are welcome mate :-)
                        But I will say that there is no need to aim the caps.
                        You can just preheat the bare PCB at the location that those caps are under it.
                        The same tecnique works even for VGA cards & laptop repairs.
                          I pre heat at the solder side of the board in the area of caps
                          thanks again
                            I use my wife`s oven when she is at work. Lot`s of good advice here.
                              2 months past since my purchase of the BK 4000 desoldering station, I repaired may be 10
                              monitors. I already wore out 1 tip. My question is how long does a desoldering tip last
                              is there a better quality tip available for this BK 4000.
                              Other then getting a better quility tip the BK 4000 desolding staion works great
                                Show to us a picture of what you consider as damage.
                                  You can teel that it is worn on side I replace it with a new 1.5mm and it works better
                                    You have get married with a low cost system, which looks to come with three spare tips in total.
                                    My advice is to use them all, and if this system are still standing regarding the health of the heat element and pump, only then move forward & buy some extra tips.
                                    Looking for quality made tips for this system is a wild dream.
                                    There is no such compatibility with solutions offered by other vendors.
                                      How long should a tip last on a better system
                                      Can you suggest a better system under 300.00
                                      Thanks kiriakos for your advice
                                        There is no easy answers when you set a budget.
                                        If you are close to start working as professional = start your own legit business and expecting an significant work flow.
                                        Some of your best bets is Weller or JBC or DEN-ON (Japan).
