Re: GTX 780tI Repair attempt...
Updates.....
PALIT GTX 780ti
I removed all the Video RAM. Due to practicality, and the way my workshop is layed out, I actually used the Kada 853B to preheat the board to about 120C and the Quick 861DW to remove the chips. All went well apart from I slipped with one RAM chip on the vacuum pickup and took out 4 nearby SMD resistors/capacitors accidentally
But that is not a disaster - I can easily work out the values and replace them, the same components repeat for each pair of RAM chips.
I cleaned up the PCB and there are no damaged pads, so that's good.. I tested for the short on Vram after removing 4, then 8 chips and the short was still there. With all chips removed it is gone and I have 110 ohms - same as my 'kinda' working board
As the VRAM FETs were faulty and the inductors are currently removed, I then powered up VRAM from my bench supply at 1.5V - something draws about 2.7A and I am pretty sure that is the GPU as it gets a bit warm. I then powered up the motherboard from ATX supply and I have a sort of result!
Basically the PC now beeps to show it detected the graphics card, and my monitor comes on so it must have video sync - but I have a blank screen. That would seem reasonable as I have no video ram on the graphics card now...... but...
I saw this video
https://www.youtube.com/watch?v=vDyTtcKndug&t=601s
I am basically doing the same thing as this guy, with similar reuslts on the current drawn from the bench PSU (I think his is a GTX780 and mine is the 780ti which makes sense mine would draw a bit more power) but he gets a picture with no video ram and I don't. Watch from 5 mins onward to see this. Unfortunately the video is in Russian and I don't understand that at all, but in the end he fixes his card, though i am not sure if he also reballs or replaces the GPU.
Does anyone here understand Russian and can explain what this guy is saying? And how he gets video output with no video ram?
I could order some Video Ram and FETs for this card, plus replace the few missing SMDs caused by my slightly dodgy desoldering.. It would cost about 20 euros in parts to continue with this one. Should I? I am tempted too, just out of curiosity.
PHANTOM GTX780
Kinda working now. I need to replace those missing 6 SMDs see if it gets rid of the artifacts in the video. If that don't fix it, is there any way to determine what is causing these? Heating / Cooling the GPU, RAM to see if it affects the picture?
GIGABYTE GTX780ti
Waiting for Stencil to replace the GPU. Needs two SMD Capacitors and a Tantalum 470uF 3V. Parts ordered.
Gigabyte GTX770
Will look at this one next see why a FET blew an hole in itself when I see no shorts
Updates.....
PALIT GTX 780ti
I saw this video
PHANTOM GTX780
GIGABYTE GTX780ti
Gigabyte GTX770
