Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 11-20-2011, 05:21 PM   #1
Slanter
Default Stupid DIYer, TV wasn't broken but it is now.
So my TV, for the past two years, has been displaying amorphous dark blobs on the screen, that didn't seem to have any sort of pattern or anything, just a slightly darker section of the screen that would really only be noticable when watching something dark.
Well I read some stuff about how that could be caused by dirt buildup either between the LCD and clear cover, or between the lamp and the LCD so I started to disassemble it to get to the LCD panel. I've replaced a lot of LCD's on monitors and laptops so I figured they'd be similar.
So I get the whole cover off and get down to the LCD panel, which is just a big glass sheet with a handful of ribbon cables along the top going to 2 circuit boards along the top. My problem was that the ribbon cables were just glued to the circuit boards with some sort of adhesive, and when I lift the screen to try to get to underside without disconnecting the ribbons four of the ribbons peeled away from their seats... and now I have no way of reconnecting the ribbons, or even determining how to line the ribbon up right on its contact area. directly below where the still-connected ribbons are seated the TV shows kinda random colors, but the rest of it is black. Am I boned or can this actually be fixed?
by the way, model of this TV is a sharp aquos lc-c3742u. Kinda old. All the previous LCD's i've dealt with just had a plug for any ribbons, but apparently sharp decided being able to replace an LCD screen easily wasn't a good idea.
Slanter is offline   Reply With Quote
Old 11-20-2011, 05:41 PM   #2
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Professional Tech
Default Re: Stupid DIYer, TV wasn't broken but it is now.
It's not possible to fix it. The ribbons are welded on, you can try and apply pressure to them to fix it, but it will be a temporary fix at best.
It's not possible to fix mura (unevenness) on LCDs, as the problem is inherent to the LCD, and has very little (nothing?) to do with the backlight or diffuser. It's a problem with the density of the liquid crystal in the panel.
The LCD is replaceable, but it comes as a module - backlight and all - and will be very expensive.
__________________
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
tom66 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
