Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 07-20-2018, 01:40 AM   #1
stevo1210
stevo1210's Avatar
City & State: Eastern coast
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Student Tech
Default DisplayPort woes
Hi Everyone.
Just bought a new LG Ultra wide monitor today. Love it to bits, however I am having an issue with displayport.
Displayport works and displays an image without issue, however if I were to turn off the monitor or simply change source... if I flick back or turn on the monitor again while the PC is still on... it displays "no signal". I would have to turn the computer off completely or reset it for the monitor to get a signal again. This behaviour does not happen on HDMI - I can turn off the monitor while my PC is still on, and switch it back on without issues.
However. I decided to grab my brothers computer which he uses DP on, and also use his expensive Amphenol DP cable (full size DP), there are absolutely no issues and it behaves as normal - ie. if I switch off the monitor and switch it on again while PC is running - it receives signal and comes out of sleep mode or whatever.
I have never used DP before so I don't know what I'm doing wrong here. The cable I am using is the one that came with my Viewsonic 4K monitor which was donated to mum. It's a DP to Mini DP because my HD6870 card only has mini DP, and not full size DP like my brothers PC.
Could it be a cheap cable issue?
Thanks.
stevo1210 is offline   Reply With Quote
Old 07-20-2018, 08:02 AM   #2
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Default Re: DisplayPort woes
cable or the connector would be my guess.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 07-20-2018, 11:05 PM   #3
stevo1210
stevo1210's Avatar
I'm a: Student Tech
Just got a different Mini DP to DP cable for it. Works fine now!
